Subject: VRF- "HOME" variable?
Author: stanb-at-sr (stanb@hpnmrsb2.sr.hp.com) at HP-USA/o2=mimegw3
Date: 7/25/97 11:54 AM
> Hi all.
> I just installed an application on my computer totally unrelated to VEE
> and when I went into VEE found that my IO Configuration was gone!
> I poked around and found that the vee.io file was still intact in the
> install directory but for some reason was not being read in by VEE.
> Strange to say the least.
> After some experimentation ( I went into vee, created a new IO config
> and saved it. Then went to my explorer and did a "find" looking
> for vee.io) I found that VEE is now looking in the new application's
> directory!
> Afetr a little more poking I found that the new application is setting
> an environment variable called HOME. And it appears that if HOME is set
> then VEE looks in the HOME directory for vee.io instead of it's own
> install directory.
> VEE _doesn't_ appear to use HOME for anything else, like default
> directory, startup directory, looking for menu files, etc.
> Any way around this?
I don't think there's a way around it. See below.
> Is this intended behavior or a bug?
Intended behavior - the following has been in the VEE help files
section titled "To Include All Needed Files" since at least VEE 3:
"When distributing your program, you need to include your instrument
configuration file. On Windows, it is located in %HOME%/vee.io, if
HOME is defined. Otherwise, it is located in C:Program
FilesHewlett-PackardVEE 4.0vee.io (unless HP VEE is installed in a
different directory). On UNIX, it is located in $HOME/.veeio. Other
files you must include (if you use them) are:
Data files.
*.cid files for instrument drivers you've written.
*.cid files for instrument drivers not installed on the destination
system.
Graphics files you've created.
DLLs or compiled functions that you call.
Copyright (c) 1991-1997 Hewlett-Packard Company"
It looks like if you have a HOME variable set, VEE'll use it.
Bruce Wenner
HP St.Paul
> Hi all.
> directory!
> install directory.
Data files.
system.
Bruce Wenner
HP St.Paul
for vee.io) I found that VEE is now looking in the new application's directory!
install directory.
Stan Bischof
stanb@sr.hp.com
Subject: Re: VRF- "HOME" variable?
To: Stan Bischof <stanb@hpnmrsb2.sr.hp.com>
Date: Fri, 25 Jul 1997 08:54:24 -0700 (PDT)
To: hpvxd_xc@hpislsup.lvld.hp.com
> Hi all.
> install directory.
> Stan Bischof
> stanb@sr.hp.com
---------------End of Original Message-----------------
Stan,
I think the intent is that HOME would/could point to a users HOME directory to be more like the way unix would behave. Personally I never use the default vee.io directory. I always set up a seperate VEE icon for each different set of hardware and use the -veeio command line option to get the corresponding IO configuration for that hardware. Just my 2 cents.
Tom Sanders
