<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META http-equiv=Content-Type content="text/html; charset=iso-8859-1"><META content="MSHTML 6.00.2800.1476" name=GENERATOR><STYLE></STYLE></HEAD><BODY bgColor=#ffffff><DIV><FONT face=Arial size=2>Ben;</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>How about using Execute Program (PC) simple good old commands.</FONT></DIV><DIV><FONT face=Arial size=2>If you need an example let me know</FONT></DIV><DIV><FONT face=Arial size=2>David Jazcilevich <A href="mailto:testardj@inter.net.il">testardj@inter.net.il</A></FONT></DIV><DIV> </DIV><BLOCKQUOTE style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px"> <DIV style="FONT: 10pt arial">----- Original Message ----- </DIV> <DIV style="BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: black"><B>From:</B> <A title=Ben.Millis@analog.com href="mailto:Ben.Millis@analog.com">Millis, Ben</A> </DIV> <DIV style="FONT: 10pt arial"><B>To:</B> <A title=vrf@agilent.com href="mailto:vrf@agilent.com">VRF</A> </DIV> <DIV style="FONT: 10pt arial"><B>Sent:</B> Wednesday, November 17, 2004 1:52 PM</DIV> <DIV style="FONT: 10pt arial"><B>Subject:</B> [vrf] Removing files</DIV> <DIV><BR></DIV> <DIV><SPAN class=981573211-17112004><FONT face=Arial size=2>Hi All,</FONT></SPAN></DIV> <DIV><SPAN class=981573211-17112004> <FONT face=Arial size=2>Can anyone help me out here? How can you get VEE to delete a file? During my program VEE produces some files that I'd like to remove when the program finishes, I've been trying to find a way of doing this without much luck. I have thought of using VEE to run a batch file to remove the files but the file to be deleted has a different name each time and I don't know how to pass that to a batch file. Any suggestions?</FONT></SPAN></DIV> <DIV><SPAN class=981573211-17112004><FONT face=Arial size=2></FONT></SPAN> </DIV> <DIV><SPAN class=981573211-17112004><FONT face=Arial size=2>Ben</FONT></SPAN></DIV>---<BR>You are currently subscribed to vrf as: testardj@inter.net.il<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". </BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
>Isn't the comparator object wonderful?
Yes, I think so, too.
> It will do a comparison of two coord arrays, even when their x-values do
not correspond.
This seems to violate the spirit of mapping, though I suppose if you had
just a few break points in your spec it might be useful.
>One would assume that for a given element of the Test Value input, if the
>Ref Value input doesn't contain an element with an exactly matching x
value,
>the comparator will interpolate between the two nearest Ref Value points,
>and compare. I knocked up a quick demo in VEE 6.2 and this appears to be
>true.
>But can anyone confirm this? The help for comparator doesn't say much. I
>would like to know, because I'm using this to make pass fail decisions in
a
>production environment. Should my client ask for technical detail of how
>that decision is made, it would be nice to be able to provide it.
Using undocumented features gives me the willies. It might be easier, and
certainly safer, to generate a coord with specification values
corresponding to every data point than to try to explain the interpolated
behavior to a client (or to yourself when you are contracted to modify it
in a couple years.)
>An unrelated observation: in the attached example, if you double click
the
>comparator's Passed output pin, it always contains a value of 1,
regardless
>of whether it passed or failed. Same if you click the line coming out of
>the pin. But this datum only propagates to subsequent objects if the
>comparison passes. Similar for the Failed output pin. Not a problem,
just
>an observation.
I've noticed that, too. It doesn't affect the operation of the program, but
it sure can confuse you while debugging.
Bill Ossmann
Philips Ultrasound
e-mail: bill.ossmann@philips.com
