> Perhaps the simplest - and most easily documented way would be to take
> advantage of the auitomatic type conversion:
> make your formula 1.0*a/b and then 4/5 will become a real.
> Alternately you could set the "required type" on one of your
> input terminals as "real" and force the type conversion.
> regards
> Stan Bischof
> rsb@sr.hp.com
Thanks Stan!
It worked fine. So easy if you know how to do it, but I'm only just getting started.
Stephan Grabeleu
> regards
> Stan Bischof
> rsb@sr.hp.com
Thanks Stan!
Stephan Grabeleu
