Hi
I have tried unsuccessfully to install a 82341D HPIB card on several 486 DX2
machines. Vee4 is currently installed on the PC under win95. when I put
the card in and boot up, w95 pnp finds the card and installs. I run the HP
ioconfig utility and it finds the card and installs. I check win95 control
panel/settings/system/hpib cards and it tells me the card is ok and there
are no conflicts. So far so good. Now I launch Vee4, run io/inst
manager/hpib-7/refresh and it finds the port and the hp437b power meter
connected to it. This I configure with the right (hp437b.cid) driver and
save.
Now comes the problem: When I try and fetch the intrument in the panel
mode, I get a "Error occured during reset of intrument i/o error or timeout
at hpib interface 7". I can increase the timeout to 60sec this doesn't
help. I try several other instruments and cables with the same problem. I
can install an 82340 card on this machine and it works first time.
I assume the card is faulty and send it back to HP, where they test it, find
it OK and send it back to me. What can I try next?????
Regards from:
Graham Lambert
Home email: greylamb@iafrica.com
http://users.iafrica.com/g/gr/greylamb/
save.
Regards from:
Graham Lambert
