Has anybody had trouble with Vee 4.1 randomly not finding drivers when
starting up? When I start VEE the message that a driver is not found,
would you like to install it now pops up. The driver listed is different
every time. The vee.io file lists the driver in question. This doen't
happen everytime I start VEE. VEE 3.2 doesn't do this. It only does it
on my Compac166. It works on a Compac133 on the shop floor. VEE Tech
Support never heard of the problem and suggested re-installing VEE,
which didn't help.
Andrew Kronquist
akronqui@burdick.com
which didn't help.
Andrew Kronquist
