vrf Excel ActiveX
Question asked by VRFuser on Jun 27, 2001
Thanks.  That worked great.
James Hetrick
CSE Test Center
Delphi Automotive Systems
EMC Technician
(330)306-1165
mailto:jim.hetrick@delphiauto.com
From:      CARNAHAN,LYLE (A-USA,ex2) [mailto:lyle_carnahan@Agilent.com]
Sent:     Thursday, June 28, 2001 1:49 PM
To:     VRF (E-mail)
Subject:     RE: vrf Excel ActiveX
James,
When you perform the Sheets.Add the new worksheet is added as the first
worksheet (order Sheet4, Sheet1, Sheet2, Sheet3) then when you get the
handle to the 3rd sheet this would be "Sheet2" (3rd sheet on the screen).
Short answer: if you move the sheets.add after the set XLSheet3 everything
works as you are expecting.
Alternate Method: use Set xlSheet3 = xlBook.Worksheets("Sheet3"); a
referencing by name works as easily as index number without worrying about
worksheet positions.
Lyle Carnahan
Technical Consultant
Agilent Technologies
40 Shattuck Road
Andover, MA 01810
(978) 681-2133
(978) 681-2340 fax
lyle_carnahan@agilent.com
From: Hetrick, Jim [mailto:jim.hetrick@delphiauto.com]
Sent: Thursday, June 28, 2001 12:55 PM
To: VRF (E-mail)
Subject: vrf Excel ActiveX
I am having a problem with the attached code.  I am adding a 3rd sheet to an
excel workbook.  Then I name all 3 sheets.  For some reason the
xlSheet3.Name function is not working.  xlSheet1.Name and 2.Name are working
fine.  Also I want to place 13 into cell 1,1 of sheet 3 and it is going into
sheet 2.  Any help would be greatly appreciated.
<<Excel Sample.vee>>
James Hetrick
EMC Test Technician/Software Developer
CSE Test Center
Phone: 330-306-1165
Email: jim.hetrick@delphiauto.com <jim.hetrick@delphiauto.com>
