Check the port setting and termination character under "Advance I/O
Configuration". The default terminating character is "
CH
______________________________ Reply Separator _________________________________
Subject: Re: VRf Re: RS-232 communication
Author: pcconsultant (pcconsultant@worldnet.att.net) at HP-Taiwan,mimegw34
Date: 10/22/97 5:00 AM
Using "Instrument Manager", "My Configuration", "Refresh" did in fact show
serial1 and serial2, and since then we no longer get an error message about
"...not configured...Error 801", but we still have no serial communication
using HP VEE. However, we know the ports are OK because using LabView we
can establish serial communications without any problem (using a motion
control package). Any further suggestions are greatly welcome.
Allison
> From: CHEAK-HONG_TAN@HP-Singapore-om6.om.hp.com
> To: rondes@rostra.com
> Cc: hpvxd_xc@hpislsup.lvld.hp.com
> Subject: VRf Re: RS-232 communication
> Date: Thursday, October 16, 1997 9:44 PM
> Just go to "Instrument Manager", click on "My configuration" and hit
> the "Refresh" button, and you will see Serial1 and Serial2
> automatically added in. Serial1 will be your COM1 and Serial2 will
be
> COM2 and so on. This assume you have COM1 & COM2 added in your I/O
> Config utility, if not, do an "Auto Add" in I/O config.
> Hope this help.
> Regards.
> C.H.
> Subject: RS-232 communication
> Author: rondes (rondes@rostra.com) at HP-Taiwan,mimegw34
> Date: 10/17/97 3:49 AM
> I'm using HP Vee 4.0 and attempting to communicate with a test board via
> RS-232 (COM 1). I can talk to the board with no problem using the old
> Window's program, Terminal.exe. However, using Direct I/O that is
> configured as serial @ addr. 9, I get the error:
> "Serial interface, at 9, is not configured for this system. .... Error
801"
> I've used sicl95iocfg.exe and siclhwconf.exe to set up HP. As far as
I
> can tell all parameters are set:
> Name: Serial, Interface: Serial, address: 9, Gateway: this host, Live
Mode:
> On, 9600 baud, No parity, 1 stop bit, 8 data bits, Xon/Xoff control.
> However, there is nothing listed in the 'Panel Driver' tab.
> What am I missing?
> Thanks for your time and attention,
> Ron DesGroseilliers
> Rostra Precision Controls
> rdesgros@rostra.com
CH
Allison
be
> Hope this help.
> Regards.
> C.H.
801"
I
Mode:
> What am I missing?
> Ron DesGroseilliers
> rdesgros@rostra.com
Allison
be
> Hope this help.
> Regards.
> C.H.
801"
I
Mode:
> What am I missing?
> Ron DesGroseilliers
> rdesgros@rostra.com
