At 08:08 26/11/97 MST, you wrote:
>> We normally use NOTEPAD objects for documenting VEE programs. When VEE
>> applications are very large the documentation objects (NOTEPAD) become
>> enough large as well. The question is:
>> Who does the NOTEPAD usage penalize a VEE program execution ?
>> At least, I assume the memory load is increased. Am I right ?
>Certainly.
>> If yes, any work around to free memory?
>If you have an object in your program, it will use its own share of memory.
>The memory won't be allocated until you load the program and run it.
>> I am talking about VEE 4.01 in compiled mode of execution.
>> Regards.
>> | Juan Vera |
>> | E-mail: jvera@mdr.indra-espacio.es |
>> | Phone: 34-1-3963986 |
>> | Fax: 34-1-3963912 |
>> | Earth Stations Department |
>> | INDRA ESPACIO S.A. |
>> | Mar Egeo 4, Pol. Ind. 1 |
>> | San Fernando de Henares |
>> | 28850 MADRID |
>> | SPAIN |
>[<>] regards -- gvg
Let us think in a VEE program as a libray of a set of functions.
All NOTEPAD documenting any function within the library can be moved to the
'Main' of this library.
Then, from another VEE program the mentioned library is imported. What is
expected to occur ?
1.- Do the NOTEPAD's (or other objects) in the 'Main' of the library occupy
memory when loading ?
2.- Does VEE complier despise any code in a 'Main' of a library ?
We did some test to check it but the conclusion are not clear.
Regards.
| Juan Vera |
| Fax: 34-1-3963912 |
| 28850 MADRID |
| SPAIN |
>Certainly.
>> Regards.
>> | Juan Vera |
>> | Fax: 34-1-3963912 |
>> | 28850 MADRID |
>> | SPAIN |
>[<>] regards -- gvg
expected to occur ?
Regards.
| Juan Vera |
| Fax: 34-1-3963912 |
| 28850 MADRID |
| SPAIN |
