VRF
I have a HPE 1300A Mainframe set up as in the printout from VIC below connected to an HP82340 HPIB card.
It appears to be running fine. I have also installed VXI plug n play drivers for this system.
I can run the stand alone PnP panels and control the switches correctly.
In HP VEE however, when I go to place a panel driver I get error 2000 (invalid card in Switchbox) and or 800 timeout errors.
In the 'Advanced driver configuration' dialog for each instrument I have the appropriate ID filename and sub address.
i.e. hpe1345a.cid sub addr 112
hpe1364a.cid sub addr 120
I can refresh each card and the icon changes to the 'connected to computer' icon.
I have changed the names and description for each to the appropiate SwitchBox1 or SwitchBox2.
What am I missing to get the panel drivers configured correctly?
Thanks
Craig Smith
VXI config printout.
System: C:PROGRA~1HEWLET~1VICVXISYS.VIC
Date Printed: 11/19/97
Physical Layout
MAINFRAME: HP E1300A B-size Mainframe
Serial Number: Not_Entered
Date Installed: 11/19/97
SLOT 0: HP E1300A B-size Mainframe
ROM Version: A.07.00
Logical Address: 0
Laddr Switch: 00000000
Servant Area: 255
SLOT 3: HP E1345A 16-Channel Relay Multiplexer
Logical Address: 112
Laddr Switch: 01110000
SLOT 4: HP E1364A 16-Channel Form C Switch
Logical Address: 120
Laddr Switch: 01111000
Reporting Structure
HP E1300A HP-IB Address: 70900 Slot 0
SwitchBox1 HP-IB Address: 70914
HP E1345A Slot 3
SwitchBox2 HP-IB Address: 70915
HP E1364A Slot 4
Downloaded Drivers
None
Hardware Test Results
E1300A(Laddr 0): passed.
SwitchBox1(Laddr 112): passed.
SwitchBox2(Laddr 120): passed.
Craig Smith
Research and Development Engineer
Tru-Test Ltd.
Ph +64 9 2745799
Fax +64 9 2746367
Email craigs@trutest.co.nz
