send q VRF-EOL_Characters vrf Kusters@TPD.TNO.NL
website: ftp://fcext3.external.hp.com/dist/mxd/index.html
to: Tjerk Kusters / VRF
date: Tuesday, 18 November 1997 0815 MST
> From: "Kusters, Tjerk" <Kusters@TPD.TNO.NL>
> To: "'VEE Relector (E-mail)'" <hpvxd_xc@hpislsup.lvld.hp.com>
> Subject: VRF: Changing the default EOL character
> Date: Tue, 18 Nov 1997 09:23:52 +0100
> Hi,
> I want to change the default EOL character in the TO FILE object.
> Currently it's "
" and I want to have only "
> Can I change it.
Yes, just go into the TO FILE object menu and select "Properties" and choose
the "Data Format" tab ... it should be straightforward.
> The help file says the default is "
> Tjerk
> _______________________________________
> Tjerk Kusters
> TNO-TPD-TU Delft
> Tel: +31-15-2692747
> Fax: +31-15-2692200
> Email: kusters@tpd.tno.nl
[<>] regards -- gvg
> Hi,
> Currently it's "
> Can I change it.
> Tjerk
> Tjerk Kusters
> TNO-TPD-TU Delft
> Tel: +31-15-2692747
> Fax: +31-15-2692200
[<>] regards -- gvg
