zdenek.rykala.fei@vsb.cz asks:
> 1) When I created any complex UserObject in my application and I want
> use this UserObject in another application.
> Have I to create the UserObject again or can I load the UserObject in
> the other application?
You can copy to clipboard (assuming windows) and paste into new
application. You can also Save Objects or Merge depending on what you
want to do. Check out help.
lBill
lBill
I have any questions ?
2) Can I disable range of value in real slider (integer slider, real
knob, integer knob) for user to couldn't change range on the front
panel.
I use HP-VEE 3.21 now.
Thank for information
