> Does anyone have a curve fitting equation/function that they would be
> willing to share? My needs are pretty simple. I just need a linear fit
> (y=ax+b) with 3 coordinates as input.
> Any help would be appreciated.
Is built into VEE already as the "linear regression" object. Simply collect
your three coords into an array and pass into the regression object.
Will get fitted data, coefficients, and a goodness factor.
Note that polynomial, log/exp fits are also there.
regards
Stan Bischof
stanb@sr.hp.com
regards
Stan Bischof
stanb@sr.hp.com
Use the Regression object from the Devices menu. For an example, see
<vee-dir>examplesanalysiscurvefit.vee. Linear, log, exponential,
etc. fits are available.
Bruce Wenner
HP St. Paul
______________________________ Reply Separator _________________________________
Subject: Vrf-Curve fit
Author: Non-HP-kfjasins (kfjasins@execpc.com) at HP-USA/o2=mimegw3
Date: 11/20/97 7:54 AM
