Vfr - Acquisition FrequencY(IES) ?
Question asked by VRFuser on Nov 25, 1997
Hello everybody,
I want to acquire data on 32 channels at different frequencies.
If I put the same frequency in every channel in the A/D Config object and
different n of Points in GetDataPanel, I get data at the same rate in the
outputs of the GetDataPanel objects.
If I put different frequencies in the channels in the A/D Config object and
the same n of Points in GetDataPanel, I also get data at the same rate in
the outputs of the GetDataPanel objects.
In this two kind of attempts, the rate I mentioned is always the lowest that
is possible to achieve.
Please note that I disconnect the Sequence Pins of GetDataPanels that should
output data at different rates!
Can anyone tell me how can I really get different acquisition frequencies ?
(Without using Collectors after, therefore "reducing the frequency")
Thanks to all!
Nuno Moreira
Nuno Moreira
DER-ITE-INETI
e-mail  : nuno.moreira@ite.ineti.pt
Address : Estrada do Pao do Lumiar
          1699 Lisboa Codex
          Portugal
Tel.    : 351.1.7162712/5141-Ext.2730
Fax.    : 351.1.7163797
