Dear Phu,
I don't think it is possible to change baud rate programmaticaly. The only
way I see at the moment is to implement several devices with different baud
rates. After that you can choose your device programmatically.
Best regards
B. Aufenanger
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon : (089) 613 984 91
Fax. : (089) 613 981 23
Email : Aufenanger@somatec.de
homepage : http://www.somatec.com
Sent: Thursday, January 14, 1999 3:02 PM
To: 'hpvxd_xc@hpislsup.lvld.hp.com'
Subject: Changing baud rate within the program
Importance: High
Hello All,
Are there any commands to change the serial baud rate within HP
VEE
program? For example, the existing program is using serial
port at
9600. I would like to tell it go to different baud rate depend
on the
unit under test's baud rate. If is it possible to change
serial port
baud rate without calling a different serial device name?
Thank you for your help in advance.
Best regards,
Phu Tran
ENI Power Technology
Best regards
B. Aufenanger
Jagdweg 7a
D-82041 Deisenhofen
Importance: High
Hello All,
VEE
port at
on the
serial port
Best regards,
Phu Tran
Are there any commands to change the serial baud rate within HP VEE
program? For example, the existing program is using serial port at
9600. I would like to tell it go to different baud rate depend on the
unit under test's baud rate. If is it possible to change serial port
Best regards,
Phu Tran
