VRf-Search array?
Question asked by VRFuser on Jun 11, 1997
VRf-Search Array?
Hi there,
What would be the fastest way to search an array for one value?
For example, I need to search an array(text) with approx. 2700 elements
containing serial numbers.  I've used a "For Count" object to cycle through
the array and compare each element with the required serial number using
the "IF/Then/Else" object.  This works, but slowly.  Is there a faster way?
Platform in use is: HP Vee 3.12, Win 3.11. PC 586 100MHz 16MB RAM..  (Maybe
I need to peddle faster).
Thanks..
David Mayes.  Test Tech.
Trio Communications 2000. (Data Radio Products)  www.trio.com.au
41 Aster ave. Carrum Downs Vic. Australia. 3201
dmayes@trio.com.au
Trio Communications 2000 Pty/Ltd -- 41 Aster Ave. Carrum Downs. 3201. Australia
Ph 61 3 9775 0505 -- Fax 61 3 9775 0606 -- Web WWW.trio.com.au -- Email dmayes@trio.com.au
