Allen,
I have run into something similar with Memory Segmantation errors.
I finally managed to isolate them down to the DECALRD GLOBALS objects.
Out project uses globals to keep track of various states and we were
trying to use DECLARED VARIABLES to keep globals in scope within
libraries. This seemed to lead to segmentation errors, and when the
DECLARATIONS were removed, the problems went away. I wish I had time
to pursue this problem, but we have a work-around now and.....you know
how it goes sometimes.
I don't know if this applies to your problem, but thought I would
share it anyway. Good Luck.
Thomas Groleau
Tucson, Arizona
______________________________ Reply Separator _________________________________
Subject: Segmentation Violation
Author: "Allen K. Lair" <alair@lois.dgim.doc.ca> at CCGATE
Date: 1/16/98 9:42 AM
I have recently upgraded from VEE 3.21 to 4.01, and when my program does a
showpanel() on a function, I get "Segmentation Violation (Signal=11), etc. etc.,
Error Number: 979". I have tried removing the showpanel() function and
replacing it using 4.01, as well as changing the properties of the user function
to Show Panel on Execute, both with the same result. Does anyone have a
suggestion?
Any help would be appreciated,
Allen
Allen K. Lair
Senior Technologist
Communications Research Centre
Kanata, Ontario, Canada
Phone: (613) 998-2374
(613) 991-9034
Fax: (613) 991-9035
Thomas Groleau
Tucson, Arizona
suggestion?
Allen
Allen K. Lair
Senior Technologist
(613) 991-9034
Fax: (613) 991-9035
