Drago, William wrote:
> Hi All,
> I'm trying to replace the values in 1 dimension of a 2 dimensional
> array with values from a 1 dimensional array.
> Other than looping thru the arrays, replacing 1 element at a time, is
> there a better way to do this?
> : Bill Drago :
> | L3 Communications |
> : Narda Microwave-East :
> | Hauppauge, NY 11788 |
> : William.Drago@L-3Com.com :
> | 516-231-1700 x572 |
Yes:
| Generate 1D Array | | Formula |
| randomize( ramp(10,0,0),0,50 ) +----->| A1 | [ A1, A2[1,*] ] +--->
+--------------------------------+ +-->| A2 | |
| Generate 2D Array | |
| [ randomize(ramp(10,0,0),50,100), randomize(ramp(10,0,0),100,150)] +--+
Don't worry about the boxes with the "randomize(ramp)" statements in them,
they just generate arrays with random contents (in distinct ranges so
you know which is which). The Formula box is the important item.
This Formula swaps the first row of the array. You can swap the second
with:
[ A2[0,*], A1 ]
[%%] regards -- gvg
Greg Goebel ftp://fcext3.external.hp.com/dist/mxd/index.html
HP MXD Marketing http://hpislsup.lvld.hp.com (HP only)
pctm@lvld.hp.com http://www.geocities.com/CapeCanaveral/Launchpad/6000
> Hi All,
> : Bill Drago :
> | L3 Communications |
> | 516-231-1700 x572 |
Yes:
with:
[ A2[0,*], A1 ]
[%%] regards -- gvg
