Matthew Johnson wrote:
> Now since I am at least one who started this recent issue, I will
> comment to the group.
> For those of you who are filtering by subject and need the VRF, why not
> just filter by email address. Somthing like if the from email address is
> blah, then filter. That way, the subjects can stay normal.
> I guess my question is why can you not filter by from address and not
> use subject? That way the sender does not have to do it, the admin does
> not have to do it, and you have to only make one change.
> matt
> On Thu, 7 May 1998, Greg Goebel wrote:
> > send q VRF-VRF_Suffix vrf
> > from: Greg Goebel / HP-MXD
> > gvg@lvld.hp.com / 800-452-4844
> > website: ftp://fcext3.external.hp.com/dist/mxd/index.html
> > to: VRF
> > date: Thursday, 07 May 1998 1212 MDT
> > Hi All:
> > One of the little rules I suggested for the VRF is to prefix messages to
> > the VRF with the suffix "VRF-".
> > Feedback I got on the issue indicated people thought it was a good idea, and
> > certainly it was no great bother. But I've been politely suggesting to people
> > when they don't follow the custom that they do so, and getting flak about it.
> > So, may I ask: who wants to keep on this custom, and who wants to drop it?
> > I'm not so particular myself.
> > As far as automating it, that's possible, but given sysadmin resources
> > (slender) and free time (slenderer) that's not a short-term option.
> > Thanks for your time and consideration.
> > [<>] regards -- gvg
> Matthew Johnson "In my mind and in my car
> finger <mrjohns2@uiuc.edu> for pgp key we can't rewind we've
> <http://www.uiuc.edu/ph/www/mrjohns2/> gone too far." -The Buggles
I think the same than Matthew (in fact I currently make this).
On the other hand, for me, it is more important the content of the subject in
order to be able to find quickly a specific item. When you have a lot of
messages (wait only a few months) and you want to find some item that was
discussed time ago, it is not very easy to find it. But I know that it is
difficult to fix this idea in a practical way.
However, I think it could have a standard header into de messages (or some of
them). In some cases it is difficult to know which is the Operating System (and
its version) related to the subject, or the machine configuration (WS, PC,
memory, Processor type), even the VEE version (3.x, 4.x, 5.x). But this data
could be very important for the problem. Therefore, I suggest to generate and
send in the reflector a template of this header that could be filled wholly or
partly or even not filled, when a technical problem is discussed.
I think HP would like this. It could have a statistical about which are the OS
or machine or VEE version more used, for example.
Bye,
______________________________________________________
Juan Carlos Martin
E-mail : jcmar@mdr.indra-espacio.es
Phone : 34-91-3963995
Fax : 34-91-3963912
Earth Stations Department
INDRA ESPACIO / MADRID /SPAIN
> matt
> > to: VRF
> > Hi All:
> > [<>] regards -- gvg
Bye,
Juan Carlos Martin
Fax : 34-91-3963912
to: VRF
Hi All:
[<>] regards -- gvg
