send q VRF-EOI_Problem ww vrf
greg_goebel@hp.com / 800-452-4844
website: ftp://fcext3.external.hp.com/dist/mxd/index.html
to: VRF-Juan Vera
date: Thursday, 21 January 1999 1614 MST
Using:
VEE 5.01
IOLIB G.02.01
54600 scope
Win98 (operates same as Win95)
E2050 LAN-HPIB
-- performing a "*RST;*CLS" gives an EOI flag on a bus analyzer connected
to the scope and LAN-HPIB box when EOI is set in VEE Instrument Manager
configuration for the scope. Eliminate that setting and the EOI goes away.
Add it again and it comes back.
No problem found. Were you using a bus analyzer to detect EOI?
[%%] gvg
--------------------------------- cut here ----------------------------------
Date: Thu, 21 Jan 1999 12:23:16 +0100 (MET)
>From: Juan Vera <jvera@mdr.indra-espacio.es>
Subject: Vrf: E2050A,VEE,SICL & EOI management
Hi all,
First of all, maybe this message should be addressed to other forum but ...
We have detected what we consider a malfunction y the E2050A LAN/HPIB gateway.
We do need to assert the EOI line after a write transaction for commanding a
device which is connected to the E2050A.
We're using VEE 5.0 as control software. Trhough the menu 'Instrument
Manager --> Device Configuration --> Advance Device Configuration' we set
the option 'END (EOI) on EOL' to 'YES'.
But the E2050A did not assert the line and hence the handsahking is not
finished and I/O operation can not be executed.
It works properly if using a HPIB PCI card.
SICL version is G.
Any solution, advice or workaround?
Thanks in advance.
| Juan Vera |
| E-mail: jvera@mdr.indra-espacio.es |
| Phone: 34-913 963 986 |
| Fax: 34-913 963 912 |
| Earth Stations Department |
| INDRA ESPACIO S.A. |
| Mar Egeo 4, Pol. Ind. 1 |
| San Fernando de Henares |
| 28850 MADRID |
| SPAIN |
to: VRF-Juan Vera
Using:
VEE 5.01
IOLIB G.02.01
54600 scope
E2050 LAN-HPIB
[%%] gvg
Hi all,
SICL version is G.
Thanks in advance.
| Juan Vera |
| 28850 MADRID |
| SPAIN |
