> Maybe this has been addressed before. Is there
> any easy way to generate PC filenames based on
> on the current date and time? What I would like
> is to have a base filename filter that then has
> the date and time of the test appended to it.
> An example filename I would like is:
> Testd_05_08_98_14_20_05
> ie;
> filter="Testd" (set by the user)
> Testd_month_day_year_HH_MM_SS
> The month, day, and year are easy, but there
> doesn't seem an easy way to get the current
> time in the string format needed for a filename.
> Any suggestions?
Send the output of the now() function to a To String object. On the To String
object, change from Default Format to Time Stamp Format and request the Time
data.
Send the time string to a From String object. Change the Default Format to
Token Format and change SPACE DELIM to EXCLUDE CHARS. Set the exclude character
list to ":
". Finally, change the SCALAR type to ARRAY 1D and changes the SIZE
argument to TO END. You'll end up with a 3 element array containing the HH, MM,
and SS.
Bruce Wenner
HP St. Paul
> ie;
> Any suggestions?
data.
list to ":
and SS.
Bruce Wenner
HP St. Paul
