Juan,
I'm not sure I understand what your box does, but I'll make a guess
that you connect from VEE via LAN to a machine that has RS-232 ports.
I would avoid SICL & direct I/O and just use the To/From Socket call.
I assume that the DEC Server support some type of tcp/ip interfacing,
which the VEE to/from socket can handle.
Mark Ahrens
Hewlett Packard T&M AEO Email: mark_ahrens@hp.com
(800)-452-4844
"Ask me about Custom Test Solutions"
>Hi VEE users:
>I'm trying to use a DEC Server 700 as interface bridge between RS-232 lines
>and Ethernet LAN bus.
>Does anybody know if it is feasible using VEE ?
>May be configuring serial ports specifying the DEC Server as its gateway.
>Need SICL for DEC Server ?
>Any idea is wellcome !!!
>Thanks in advance.
>| Juan Vera |
>| E-mail: jvera@mdr.indra-espacio.es |
>| Phone: 34-1-3963986 |
>| Fax: 34-1-3963912 |
>| Earth Stations Department |
>| INDRA ESPACIO S.A. |
>| Mar Egeo 4, Pol. Ind. 1 |
>| San Fernando de Henares |
>| 28850 MADRID |
>| SPAIN |
Mark Ahrens
(800)-452-4844
>Hi VEE users:
>Thanks in advance.
>| Juan Vera |
>| Fax: 34-1-3963912 |
>| 28850 MADRID |
>| SPAIN |
Hi VEE users:
Thanks in advance.
| Juan Vera |
| Fax: 34-1-3963912 |
| 28850 MADRID |
| SPAIN |
