Sender: Non-HP-scottmo/HP-PaloAlto_mimegw2////////HPMEXT1/scottmo#a#sonic#f#net@boi164
FROM: Non-HP-scottmo/HP-PaloAlto_mimegw2////////HPMEXT1/scottmo#a#sonic#f#net@boi164
TO: stan_bischof@hp.com
Date: Mon, 08 Sep 1997 18:44:48 -0700
To: stan_bischof@hp.com
Subject: Thank you. Thank you. Thank you. Thank you. Thank you. Thank you.
Thanks Stan,
In the re-installation of VEE I selected all the install options and
everything is well! I've received a response (<24 hrs) from the vee
support folks in lvld. It seems what I was seeing was a bug! The
giveaway is the error message referencing 'missing hpidc'. I'm
forwarding the message from lvld to you.
Thanks again,
Scott x73521
PS I'll put the disks on your chair in the morning.
Thanks Stan,
Thanks again,
Scott x73521
