Hi folks;
We have developed parallel port code that talks to a system via windows
NT , the code is in C++ and is being imported to DLL to be used in VEE.
Is there an easier way to tackle this using Vee to directly control
Parallel port of PC.
Is there a canned program to write to parallel port using Vee, can one
be easily written and tried out.
Which one is easier to your opinion to use: the HPGPIO card E2074, and
generate the 20 functions we need or use existing developed c++ code and
get the DLL library imported to vee. Who has done a DLL from start to
end in VEE?. I have read the example of DLL that Vee covers.
Please let me know what do you think is a better approach. Currently I
am going in parallel with both approach.
Regards
Albert
Regards
Albert
