>Date: Fri, 28 May 1999 07:37:42 -0400 >From: Eric Smith <esmith@fallschurch.esys.com> >X-Mailer: Mozilla 4.5 [en] (WinNT; I) >X-Accept-Language: en >To: VEE Reflector <hpvxd_xc@hpislsup.lvld.hp.com> >Subject: Can HPVEE play sound files? > >Hello all, > >Is there any way to make VEE play a sound file? I want to use sound >files as an auditory pass / fail indication? If so, what format does >the sound file have to be in? > >Thanks, >-- >Eric Smith - Test Engineer >Raytheon Systems Co. >7700 Arlington Blvd. ML09 >Falls Church, VA 22042 > >Internet: esmith@fallschurch.esys.com >Phone: (703)560-5000 x4163 >FAX: (703) 208-1219 > > > Hello Eric,
You can use an ActiveX Control such as Window MediaPlayer Control (can play .wav,.mid,...? extension files), but it is not the only one. Hope this help you. Regards.
Laurent PERDEREAU UMR 6530 - Gotectonique, Gophysique, Mtallognie CNRS / Centre National de la Recherche Scientifique 3D, Avenue de la Recherche Scientifique 45071 ORLEANS CEDEX 2 (FRANCE) Tel. (33) 2 38 25 52 40 Fax. (33) 2 38 25 76 50 Email : perdero@cnrs-orleans.fr
>Hello all,
>Thanks,
>FAX: (703) 208-1219
Hello Eric,
Hope this help you.
Regards.
Laurent PERDEREAU
