You don't want to do that, its bad news anyway. If you enter the loop, you
will not exit user object untill the XeQ pin is activated. So even if you
could connect it, it would not work. The For range belongs inside with the
collector.
Sent: Thursday, April 08, 1999 11:54 AM
To: VEE Reflector
Subject: VRF: attaching the sync pin to user object.
Dear all,
Attached is a program containing a problem I have. It contains a "for
range", a "collector" and a "AlphaNumeric" window. If I now place the
collector and alpha in a userobject having two inputs -being data and
sync- I am unable to connect the sync pin. any ideas why?
David.
Mr. David Birkin.
Dept of Physics and Astronomy, Telephone: (01334) 476161 ext 3124
University of St Andrews, Fax: (01334) 463104
North Haugh, Email: djlb@st-andrews.ac.uk
St Andrews.
KY16 9SS
Scotland.
collector.
To: VEE Reflector
Dear all,
David.
Mr. David Birkin.
St Andrews.
KY16 9SS
Scotland.
collector.
To: VEE Reflector
Dear all,
David.
Mr. David Birkin.
St Andrews.
KY16 9SS
Scotland.
