All ISA (IBM PC/AT and compatible) computer systems generate a hardware
interrupt on IRQ0 18.2 Hz. This interrupt is mapped to INT 8 and can be
intercepted by any application that wants to hook it. At 18.2 Hz, the
interrupt occurs approximately once every 55 ms. The Windows system driver
hooks INT 8 and maintains the value returned by the GetTickCount function.
Thus, this value is accurate only to within 55 ms.
Get one of those ActiveX timer controls. I downloaded one from
http://www.mabry.com/hitime/index.htm but have never found the time to try
it out. Supposedly this will do what you need.
From: Alfred Holmberg [mailto:alfred.holmberg@norske-skog.com]
Sent: Thursday, June 10, 1999 2:32 AM
To: hpvxd_xc@hpislsup.lvld.hp.com
Subject: RE: Need help. Millisecond timing
I have rougly the same problem. I want to calculate events per second.
Present I read two event counters at about 1 sec. intervals and divide on
time interval using successive "now()" readings. I use 5.01 version under
Win95, and have also noticed the 10 ms resolution.
But to obtain neccessary accuracy I need 2 ms resolution or better. So I
would be very grateful for any suggestions on how to come around this
problem, if possible without resorting to additional external electronics.
I have noticed that the "Tmer" has split millisecond resolution, but can
its accuracy be trusted ?
Hopefully
Alfred Holmberg
Norske Skog ASA
7620 SKOGN
Norway
E-mail: alfred.holmberg@norske-skog.com
Hopefully
Alfred Holmberg
Norske Skog ASA
7620 SKOGN
Norway
