send q VRF-ActiveX_Control_Problem vrf ww
greg_goebel@hp.com / 800-452-4844
website: ftp://fcext3.external.hp.com/dist/mxd/pc/index.html
to: VRF
date: Monday, 21 June 1999 1427 MDT
Hi All:
Notes from our lab folks. Yes, there is work on problems like these. GVG
--------------------------------- cut here ----------------------------------
Can you reply to this guy on the VRF with the info that sorry we don't
support this control?
Thanks / Sz
>From: Keef
This from the VEE Help file:
HP VEE does not support all ActiveX Controls. If a control is incompatible
with HP VEE, an error will probably occur when you add the control to your
program or while you are using it.
At the time HP VEE 5.01 was released, the following ActiveX Control was known
to not work well with HP VEE, and you should not use it:
Microsoft Forms Object Library
Copyright (c) 1991-1998 Hewlett-Packard Company
>From: Laurent PERDEREAU [mailto:perdero@cnrs-orleans.fr]=20
Sent: Monday, June 14, 1999 8:59 AM
Subject: Vrf: ActiveX control pb
Hi Vee users,
I would like to use Spin button ActiveX control I got from Microsoft = Forms
2.0 Object Library. I can create it, but VEE does not display the
user-interface of the control, just a window with a grey background. There
is no Visible = property with the control.
Thanks for your ideas.
Laurent PERDEREAU
to: VRF
Hi All:
Thanks / Sz
>From: Keef
Hi Vee users,
Laurent PERDEREAU
