At 16:17 21/01/99 -0700, you wrote:
> VEE 5.01
> IOLIB G.02.01
> 54600 scope
> Win98 (operates same as Win95)
> E2050 LAN-HPIB
>-- performing a "*RST;*CLS" gives an EOI flag on a bus analyzer connected
>to the scope and LAN-HPIB box when EOI is set in VEE Instrument Manager
>configuration for the scope. Eliminate that setting and the EOI goes away.
>Add it again and it comes back.
>No problem found. Were you using a bus analyzer to detect EOI?
I wasn't.
But,
I'm afraid that what your solution does not solve the problem."*RST;*CLS"
are SCPI commands and my device does not conform to this standard. Moreover,
if we perform a clear, the device goes into a initialization process, which
is not acceptable.
But the remaining question is why the EOI works using the PCI card and it
does not work with the E2050A.
Regards.
| Juan Vera |
| E-mail: jvera@mdr.indra-espacio.es |
| Phone: 34-913 963 986 |
| Fax: 34-913 963 912 |
| Earth Stations Department |
| INDRA ESPACIO S.A. |
| Mar Egeo 4, Pol. Ind. 1 |
| San Fernando de Henares |
| 28850 MADRID |
| SPAIN |
> VEE 5.01
> IOLIB G.02.01
> 54600 scope
> E2050 LAN-HPIB
I wasn't.
But,
is not acceptable.
Regards.
| Juan Vera |
| 28850 MADRID |
| SPAIN |
> I wasn't.
Then why do believe EOI was not being asserted? As it is clear from
tests that it does in fact work, I think you have some other problem and
have come to a incorrect assumption as to its nature.
Greg Goebel ftp://fcext3.external.hp.com/dist/mxd/index.html
HP MXD Marketing http://hpislsup.lvld.hp.com (HP only)
pctm@lvld.hp.com http://www.geocities.com/CapeCanaveral/Launchpad/6000
