Hi Rachel,
I don't think there is a difference between the LaserJet and the DeskJet
commant. I actually don' have a manual of the DeskJet 600 or whatever you
use. But I have a manual of DeskJet500. There is no difference between this
commands. Are you sure, that you use the "FormFeed" sign at the last byte of
your side. If not there can be an overflow.
Best regards
Barbara Aufenanger
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon : (089) 613 984 91
Fax. : (089) 613 981 23
Email : Aufenanger@somatec.de
homepage : http://www.somatec.com
From: rachell ledrman [mailto:rachell@rafael.co.il]
Sent: Tuesday, February 09, 1999 4:09 PM
To: B. Aufenanger
Cc: 'hpvxd_xc@hpislsup.lvld.hp.com'
Subject: RE: VRF-VEE5.01 on Win95 & Deskjet printers
At 11:09 09/02/99 -0000, you wrote:
> <<Printeraccess.vee>>
>Hi Rachel,
>If you use a "to file"-object to LPT1 instead of a "to
printer"-object you
>can send escape sequences to the printer. It works also fine when
the
>printer is installed at the server. I am using a LaserJet. But it
should
>also work with the same escape sequence with your DeskJet.
>Best regards
>B. Aufenanger
>Jagdweg 7a
>D-82041 Deisenhofen
> Sent: Monday, February 08, 1999 3:01 PM
> To: 'hpvxd_xc@hpislsup.lvld.hp.com'
> Subject: VRF-VEE5.01 on Win95 & Deskjet printers
> Hello all,
> Does anyboy know how to change the printer status to
Landscape or
>PPortrait
> with a command from VEE ?
> Regards
> Rachel
>Content-Type: application/octet-stream;
> name="Printeraccess.vee"
>Content-Disposition: attachment;
> filename="Printeraccess.vee"
>Content-Location: ATT-0-29D8E0F850BFD211B7F40020AFB5A505-P
> RINTE%7E1.VEE
>Attachment Converted: "c:eudoraattachPrinteraccess.vee"
Hi B. Aufenanger,
Thank you for your answer.
It works fine if you just use - to file - LPT1. But I also print
graphs in
the same program and strange things happen. If I first print, the
printer
does not print the graph later (I print it with the plot terminal on
the XY
Trace or with the menu on the right button of the mouse) and a red
light
appears on the printer. After I quit the program and start it again
and
restart the printer, somehow the printer does not print the under
score line.
The situation is real bad in a program where I use ISA bus cards.
The first
time I approuch a configuration object I get a red error message
999.
Could it be because the Deskjet commands are not exactly the
LaserJet
commands ?
Regards
Rachel
Best regards
Barbara Aufenanger
Jagdweg 7a
D-82041 Deisenhofen
To: B. Aufenanger
>Hi Rachel,
printer"-object you
the
should
>Best regards
>B. Aufenanger
>Jagdweg 7a
>D-82041 Deisenhofen
> Hello all,
Landscape or
>PPortrait
> Regards
> Rachel
> RINTE%7E1.VEE
Hi B. Aufenanger,
graphs in
printer
the XY
light
and
score line.
The first
999.
LaserJet
commands ?
Regards
Rachel
Does anyboy know how to change the printer status to Landscape or PPortrait
Regards
Rachel
