Hi All
I am using vee 5_01on a pII 233 with 64mb of mem running win95 osr2. As part
of the test we run a dos application to control the device under test. This
all works fine except the dos programme seems to leave a bit of memory open.
If I use sysmon I can see the swap file in use going up and up the free
memory leaking away. Are their any utilities that run under vee 5_01 that I
can interrogate the amount of swap file/free memory in use, which can
trigger a warm boot at the end of current test?
Phone +44 (0)1908 221344 M/A-COM Ltd
Fax +44 (0)1908 221366 Featherstone Road
mstrutt@amp.com Wolverton Mill
Principal Test Engineer Milton Keynes
MK12 5EW
A little learning is a dangerous thing.
Drink deep, or taste not the Pierian spring.
(Alexander Pope 1688-1744)
MK12 5EW
MK12 5EW
