to: VRf-Christian Reimann
date: Sunday, 26 May 1996 0808 MDT
> - is it possible to change the title or any other object-property during
> execution?
Not the title. However, it would seem just as easy to hide the title bar and
put an alphanumeric display above the picture object.
> We have an amount of cameras. To identify them we want to replace the title
> with the camera-position.
> - We want to draw a line in a picture-control, therefore is it possible to
> get information on which pixel the mousebutton has been pressed?
No. We have had many requests for the ability to read mouse inputs from Graph
objects (generally to read marker position) and considered doing this in the
last revision, but couldn't come up with a clean implementation.
> Christian Reimann
If you have more questions, let us know.
[<>] regards -- gvg
> execution?
> Christian Reimann
[<>] regards -- gvg
execution?
get an information on which pixel the mousebutton has been pressed?
Christian Reimann
From: Jaap Schuurmans <schuurmn@ehv.sc.philips.com>
Subject: Re: VRf-HPGL files
To: stanb@hpnmrsb2.sr.hp.com (Stan Bischof)
Date: Tue, 28 May 1996 9:14:10 METDST
Hello Stan,
> > I've written a routine to read HPGL files and send the drawing to an
> > XY object. But, this does not work fine.
> > Does HP plan to include this ability in near future revisions of VEE ?
> I have a similar need and solution, and it seems acceptable.
Do you mean, you can actually read HPGL generated by an instrument, and have it
downloaded to a file inside VEE? I tried this a while a go and even asked HP
for support but I never succeeded. I am very interested in your solution. Wold
you be so kind and share some of it?
thanks in advance!
Jaap Schuurmans
| Jaap Schuurmans Philips Semiconductors B.V. |
| E-mail: schuurmn@sce.philips.nl PCALE |
| Seri: schuurmn@nlsce1 Building BE445 |
| Phone: +31-40-27 22058 P.O. BOX 218 |
| fax : +31-40-27 22764 5600 MD Eindhoven, The Netherlands |
