> > I got a : Serious Error
> > Internal error : Invalid Widget Model
> > Error number : 999
> > and trying to shift to panel gave this result :
> > Serious Error
> > Internal error : Segmentation violation(signal=11)
> > error number : 979
> > I was deleting some objects that was added to panel in detail view.
> > And when i pressed Save it cut.
> > To Bad. :-[
> Is this a repeatable problem? Or did it just happen once?
I've run into this several times. I have a UserObject with panel view.
In detail view I 'cut' something (one time, I think it was label) which has
been visible in panel view. Then I change to panel view. The label is still
visible there, and when I put the mouse cursor on it I get these
horrifying bright-red messages about internal errors, messages to
non-existent objects, possibly corrupted program, and contacting HP support.
Sorry about not being more precise, haven't had time to chase the bug.
Don't know the exact steps to repeat it; of course it does not happen
every time in the abovenetioned scenario. As a preventive medicine, I try to
remember to delete objects first in panel view, then cut them in detail
view.
Oh yes the system: HP VEE 3.2 and Win95. Various 486s and Pentiums
with 16 MB of RAM. Self-written serial communications with educational
measurement gear.
> > Error number : 999
> > Serious Error
> > error number : 979
> > To Bad. :-[
view.
measurement gear.
to: Henrik Grevelund
date: Monday, 22 July 1996 1001 MDT
> Hi' all
> Error number : 999
> Serious Error
> error number : 979
> To Bad. :-[
> Another thing : I save some data on unix, and when i try to read the file
> into Excell it looks like this :
> Data;data
> Empty line
> Data;Data
> Empty line
> etc.
> properly something about EOL char. Anyone got the solution ?
Hmm ... what does the source file look like, and can you determine the EOL
string? (Use DOSSHELL, press F9 to view the file, press F9 to toggle between
ASCII and hex display.
> ____________________
> / Henrik Grevelund
> |mkpkor@inet.uni-c.dk|
Please stay in touch.
[<>] regards -- gvg
