You may wish to look at the Data Translation DT21-EZ. It is similar to the
DAS-16 and is compatible with VEE 3.12 and 3.2 (via DT-VEE extensions).
Few companies, if any, are as tightly integrated with HP-VEE as Data
Translation.
It's easy to use oddball 488 bus equipment by doing direct I/O, but ISA-bus
cards from other companies would probably require you to write low level
drivers in C.
Jim Kneale kneale.j.b@smtpgty.bwi.wec.com
ph (410)712-2248 /// Northrup Grumman ESSD
fax (410)712-2815 (..) Baltimore MD USA
----------------ooO-()-Ooo------------------
#include "std_disclaimer.h" //opinions are my own
______________________________ Reply Separator _________________________________
Subject: VEE & Keithly DAS-16 card
Author: "Fulkerson; Barry" <bf02858%po3@cobe.com> at BALT.SMTP
Date: 3/18/96 4:59 PM
Will HP-VEE work with the Keithly Metabyte DAS-16 data acquisition card?
Barry Fulkerson, fulkersonb@cobe.com
Translation.
drivers in C.
