Henrik writes about propagation issue in his model:
>press the OK buttom to set the scales, nothing happens !
>If I set a delay after the virtual source then it works.
>By for now.
> Henrik Grevelund
> mkpkor@inet.uni-c.dk
Just glancing at this I wouldn't expect the OK button to do anything
since it is in a seperate subthread from the "until break" which
is spitting out continuous waveforms. The OK button shouldn't operate
until this "until break" finishes
Try making this a single thread like the below model, so that the
OK is pinged. I think that this will do what you want. Please excuse
me though if I have misunderstood the issue!
regards
Stan "VEE user - not a developer" Bischof
stanb@sr.hp.com
(saveFormat "2.0")
(date "Fri 26/Jul/1996 08:39:23 PDT")
(veerev "3.21")
(platform "HP9000s700")
(SaveCF no)
(filterNAN 0)
(component 0 ROOTCONTEXT
(name "Untitled")
(implementation
(retainGlobals YES)
(locked no)
(trigMode deg)
(nextID 21)
(component 0 TORECORD
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(component 1 YPLOT
(name "Strip Chart")
(interface
(input 1
(name "Trace1")
(lock constraints)
(input 2
(type control)
(name "Scales")
(tag "ScalesRecord")
(requires
(datatype Record)
(lock name constraints)
(optional yes)
(implementation
(tracePin 1)
(graphMode strip)
(component 2 VFUNCTIONGENERATOR
(interface
(output 1
(name "Func")
(implementation
(function Sine)
(frequency 1000)
(amplitude 1)
(dcOffset 0)
(phaseShift 0)
(numPoints 1024)
(interval 0.02)
(degRad Deg)
(errorOnAlias 1)
(component 3 LITERALCONSTANT
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "X")
(initValue Text
(data "")
(component 4 LITERALCONSTANT
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(component 5 SLIDER
(name "Real Slider")
(interface
(output 1
(name "Real")
(implementation
(value Real
(values range 0 30000)
(data 19709.302)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 6 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 28430.233)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 7 JUNCTION
(name "JCT")
(interface
(input 1
(name "A")
(input 2
(name "B")
(output 1
(name "Data")
(component 8 LITERALCONSTANT
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "y")
(initValue Text
(data "")
(component 9 LITERALCONSTANT
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(component 10 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(values range -10 10)
(data -1.744)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 11 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 8.023)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 12 TORECORD
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(component 15 START25
(component 17 REPEATUNTILBREAK
(interface
(output 1
(name "Continuous")
(component 18 CONFIRM25
(interface
(output 1
(name "Go")
(implementation
(component enterButton yes)
(component escapeButton yes)
(component 20 NEXT
(configuration
(connect D3:1 D0:1)
(connect D4:1 D0:2)
(connect D5:1 D0:3)
(connect D6:1 D0:4)
(connect D2:1 D1:1)
(connect D7:1 D1:2)
(connect D14:1 D2:0)
(connect D15:1 D5:0)
(connect D15:1 D6:0)
(connect D0:1 D7:1)
(connect D12:1 D7:2)
(connect D15:1 D10:0)
(connect D15:1 D11:0)
(connect D8:1 D12:1)
(connect D9:1 D12:2)
(connect D10:1 D12:3)
(connect D11:1 D12:4)
(connect D13:0 D14:0)
(connect D14:1 D15:0)
(connect D2:0 D16:0)
(viewFor -1
(active detail)
(detail
(geometry 0 53 1260 697)
(configuration
(viewFor 0
(active detail)
(icon
(geometry 763 445 95 51)
(iconImage "build.icn")
(detail
(geometry 486 449 98 82)
(terminals on)
(viewFor 1
(active detail)
(icon
(iconImage "display.icn")
(detail
(geometry 794 219 293 262)
(displayMode scrollGraph)
(graphType cartesian)
(gridType off)
(scale 0
(name "M345linger")
(domainName "M345linger")
(pen 9)
(show 1)
(range -1.744 8.023 4 linear)
(domain 0 8720.931000000004 4 linear)
(trace 0 onScale 0
(name "Trace1")
(pen 4)
(lineType 1)
(pointType 0)
(stepSize 1)
(trackingEnabled 1)
(viewFor 2
(active detail)
(icon
(iconImage "virtual.icn")
(detail
(geometry 245 213 220 175)
(terminals on)
(viewFor 3
(active detail)
(icon
(detail
(geometry 153 426 214 29)
(viewFor 4
(active detail)
(icon
(detail
(geometry 153 486 214 29)
(viewFor 5
(active detail)
(icon
(detail
(geometry 161 549 119 222)
(layout vertical)
(fastmode off)
(viewFor 6
(active detail)
(icon
(detail
(geometry 351 569 119 222)
(layout vertical)
(fastmode off)
(viewFor 7
(active icon)
(icon
(geometry 726 428 28 25)
(detail
(terminals on)
(viewFor 8
(active detail)
(icon
(detail
(geometry 543 576 214 29)
(viewFor 9
(active detail)
(icon
(detail
(geometry 543 636 214 29)
(viewFor 10
(active detail)
(icon
(detail
(geometry 551 699 119 222)
(layout vertical)
(fastmode off)
(viewFor 11
(active detail)
(icon
(detail
(geometry 741 719 119 222)
(layout vertical)
(fastmode off)
(viewFor 12
(active detail)
(icon
(detail
(geometry 876 599 98 82)
(terminals on)
(viewFor 15
(active detail)
(icon
(detail
(geometry 226 70 49 20)
(title off)
(viewFor 17
(active icon)
(icon
(geometry 67 195 86 51)
(iconImage "loop.icn")
(detail
(terminals on)
(viewFor 18
(active detail)
(icon
(detail
(geometry 86 320 49 20)
(title off)
(viewFor 20
(active icon)
(icon
(geometry 561 383 38 15)
(detail
(terminals on)
(connect D3:1 D0:1
(points 4 369 440 390 440 390 460 433 460)
(connect D4:1 D0:2
(points 4 369 500 390 500 390 480 433 480)
(connect D5:1 D0:3
(points 4 282 660 400 660 400 500 433 500)
(connect D6:1 D0:4
(points 6 472 680 490 680 490 540 420 540 420 520 433 520)
(connect D2:1 D1:1
(points 4 507 300 530 300 530 280 791 280)
(connect D7:1 D1:2
(points 4 756 440 770 440 770 420 791 420)
(connect D14:1 D2:0
(points 5 155 220 190 220 190 170 360 170 360 192)
(connect D15:1 D5:0
(points 7 137 330 160 330 160 360 130 360 130 510 220 510 220 528)
(connect D15:1 D6:0
(points 9 137 330 160 330 160 360 130 360 130 790 300 790 300 540 410 540 410
548)
(connect D0:1 D7:1
(points 4 646 490 670 490 670 430 723 430)
(connect D12:1 D7:2
(points 6 1036 640 1060 640 1060 540 700 540 700 450 723 450)
(points 11 137 330 160 330 160 360 130 360 130 790 310 790 310 810 500 810 500
660 610 660 610 678)
(points 13 137 330 160 330 160 360 130 360 130 790 310 790 310 810 500 810 500
550 710 550 710 540 800 540 800 698)
(connect D8:1 D12:1
(points 4 759 590 770 590 770 610 823 610)
(connect D9:1 D12:2
(points 4 759 650 780 650 780 630 823 630)
(points 6 672 810 720 810 720 680 790 680 790 650 823 650)
(points 6 862 830 880 830 880 690 810 690 810 670 823 670)
(points 6 250 92 250 100 230 100 230 110 110 110 110 192)
(points 5 155 220 180 220 180 270 110 270 110 317)
(connect D2:0 D16:0
(points 8 360 390 360 400 380 400 380 410 530 410 530 360 580 360 580 380)
(stackingOrder 2 3 4 5 6 0 9 12 8 7
11 1 13 14 15 10 16)
(titleBg "Gray")
(titleFg "Black")
(numberFormats
(realFormat standard)
(realSigDigits 4)
(realRadixSpec 4)
(integerBase decimal)
>By for now.
> Henrik Grevelund
regards
stanb@sr.hp.com
(saveFormat "2.0")
(veerev "3.21")
(SaveCF no)
(filterNAN 0)
(name "Untitled")
(implementation
(retainGlobals YES)
(locked no)
(trigMode deg)
(nextID 21)
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(component 1 YPLOT
(interface
(input 1
(name "Trace1")
(lock constraints)
(input 2
(type control)
(name "Scales")
(requires
(datatype Record)
(optional yes)
(implementation
(tracePin 1)
(graphMode strip)
(interface
(output 1
(name "Func")
(implementation
(function Sine)
(frequency 1000)
(amplitude 1)
(dcOffset 0)
(phaseShift 0)
(numPoints 1024)
(interval 0.02)
(degRad Deg)
(errorOnAlias 1)
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "X")
(initValue Text
(data "")
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(component 5 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 19709.302)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 6 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 28430.233)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(name "JCT")
(interface
(input 1
(name "A")
(input 2
(name "B")
(output 1
(name "Data")
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "y")
(initValue Text
(data "")
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(interface
(output 1
(name "Real")
(implementation
(value Real
(data -1.744)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 8.023)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(interface
(output 1
(name "Continuous")
(interface
(output 1
(name "Go")
(implementation
(component 20 NEXT
(configuration
(connect D3:1 D0:1)
(connect D4:1 D0:2)
(connect D5:1 D0:3)
(connect D6:1 D0:4)
(connect D2:1 D1:1)
(connect D7:1 D1:2)
(connect D0:1 D7:1)
(viewFor -1
(active detail)
(detail
(configuration
(viewFor 0
(active detail)
(icon
(detail
(terminals on)
(viewFor 1
(active detail)
(icon
(detail
(gridType off)
(scale 0
(name "M345linger")
(pen 9)
(show 1)
(trace 0 onScale 0
(name "Trace1")
(pen 4)
(lineType 1)
(pointType 0)
(stepSize 1)
(trackingEnabled 1)
(viewFor 2
(active detail)
(icon
(detail
(terminals on)
(viewFor 3
(active detail)
(icon
(detail
(viewFor 4
(active detail)
(icon
(detail
(viewFor 5
(active detail)
(icon
(detail
(layout vertical)
(fastmode off)
(viewFor 6
(active detail)
(icon
(detail
(layout vertical)
(fastmode off)
(viewFor 7
(active icon)
(icon
(detail
(terminals on)
(viewFor 8
(active detail)
(icon
(detail
(viewFor 9
(active detail)
(icon
(detail
(viewFor 10
(active detail)
(icon
(detail
(layout vertical)
(fastmode off)
(viewFor 11
(active detail)
(icon
(detail
(layout vertical)
(fastmode off)
(viewFor 12
(active detail)
(icon
(detail
(terminals on)
(viewFor 15
(active detail)
(icon
(detail
(title off)
(viewFor 17
(active icon)
(icon
(detail
(terminals on)
(viewFor 18
(active detail)
(icon
(detail
(title off)
(viewFor 20
(active icon)
(icon
(detail
(terminals on)
(connect D3:1 D0:1
(connect D4:1 D0:2
(connect D5:1 D0:3
(connect D6:1 D0:4
(connect D2:1 D1:1
(connect D7:1 D1:2
(connect D14:1 D2:0
(connect D15:1 D5:0
(connect D15:1 D6:0
548)
(connect D0:1 D7:1
(connect D12:1 D7:2
(connect D8:1 D12:1
(connect D9:1 D12:2
(connect D2:0 D16:0
(titleBg "Gray")
(titleFg "Black")
(numberFormats
(realSigDigits 4)
(realRadixSpec 4)
By for now.
Henrik Grevelund
P.S. I have some problems with sending mail to the forum, so if this mail
isnt complete, then please send me a mote !
-------cut here--------
(saveFormat "2.0")
(date "Fri 26/Jul/1996 09:00:31 METDST")
(veerev "3.2")
(SaveCF no)
(filterNAN 0)
(name "Untitled")
(implementation
(locked no)
(trigMode deg)
(nextID 19)
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(component 1 YPLOT
(interface
(input 1
(name "Trace1")
(lock constraints)
(input 2
(type control)
(name "Scales")
(requires
(datatype Record)
(optional yes)
(implementation
(tracePin 1)
(graphMode strip)
(interface
(output 1
(name "Func")
(implementation
(function Sine)
(frequency 1000)
(amplitude 1)
(dcOffset 0)
(phaseShift 0)
(numPoints 1024)
(interval 0.02)
(degRad Deg)
(errorOnAlias 1)
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "X")
(initValue Text
(data "")
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(component 5 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 14651.163)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(component 6 SLIDER
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 28430.233)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(name "JCT")
(interface
(input 1
(name "A")
(input 2
(name "B")
(output 1
(name "Data")
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "y")
(initValue Text
(data "")
(name "Text")
(interface
(output 1
(name "Text")
(implementation
(value Text
(data "M345linger")
(initValue Text
(data "")
(interface
(output 1
(name "Real")
(implementation
(value Real
(data -1.744)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(interface
(output 1
(name "Real")
(implementation
(value Real
(data 8.023)
(autoTrigger on)
(initValue Real
(data 0)
(detents 0.001)
(interface
(input 1
(name "Scale")
(optional yes)
(input 2
(name "Name")
(optional yes)
(input 3
(name "Min")
(optional yes)
(input 4
(name "Max")
(optional yes)
(output 1
(name "Record")
(tag "Record")
(lock constraints)
(implementation
(outputType scalar)
(component 14 REPEATUNTILBREAK
(interface
(output 1
(name "Continuous")
(interface
(output 1
(name "Continuous")
(interface
(output 1
(name "Go")
(implementation
(configuration
(connect D3:1 D0:1)
(connect D4:1 D0:2)
(connect D5:1 D0:3)
(connect D6:1 D0:4)
(connect D2:1 D1:1)
(connect D7:1 D1:2)
(connect D13:1 D2:0)
(connect D16:1 D5:0)
(connect D16:1 D6:0)
(connect D0:1 D7:1)
(connect D16:1 D10:0)
(connect D16:1 D11:0)
(connect D14:0 D13:0)
(connect D14:0 D15:0)
(connect D15:1 D16:0)
(viewFor -1
(active detail)
(detail
(geometry 0 53 995 661)
(configuration
(viewFor 0
(active detail)
(icon
(detail
(geometry 446 289 98 82)
(terminals on)
(viewFor 1
(active detail)
(icon
(detail
(geometry 754 59 293 262)
(gridType off)
(scale 0
(name "M345linger")
(pen 9)
(show 1)
(range -1.744 5.116000000000001 4 linear)
(domain 0 174.4189999999944 4 linear)
(trace 0 onScale 0
(name "Trace1")
(pen 4)
(lineType 1)
(pointType 0)
(stepSize 1)
(trackingEnabled 1)
(viewFor 2
(active detail)
(icon
(detail
(geometry 205 53 220 175)
(terminals on)
(viewFor 3
(active detail)
(icon
(detail
(geometry 113 266 214 29)
(viewFor 4
(active detail)
(icon
(detail
(geometry 113 326 214 29)
(viewFor 5
(active detail)
(icon
(detail
(geometry 121 389 119 222)
(layout vertical)
(fastmode off)
(viewFor 6
(active detail)
(icon
(detail
(geometry 311 409 119 222)
(layout vertical)
(fastmode off)
(viewFor 7
(active icon)
(icon
(geometry 686 268 28 25)
(detail
(terminals on)
(viewFor 8
(active detail)
(icon
(detail
(geometry 503 416 214 29)
(viewFor 9
(active detail)
(icon
(detail
(geometry 503 476 214 29)
(viewFor 10
(active detail)
(icon
(detail
(geometry 511 539 119 222)
(layout vertical)
(fastmode off)
(viewFor 11
(active detail)
(icon
(detail
(geometry 701 559 119 222)
(layout vertical)
(fastmode off)
(viewFor 12
(active detail)
(icon
(detail
(geometry 836 439 98 82)
(terminals on)
(viewFor 14
(active icon)
(icon
(geometry 207 -45 86 51)
(detail
(terminals on)
(viewFor 15
(active detail)
(icon
(detail
(geometry 186 -90 49 20)
(title off)
(viewFor 17
(active icon)
(icon
(geometry 27 35 86 51)
(detail
(terminals on)
(viewFor 18
(active detail)
(icon
(detail
(geometry 46 160 49 20)
(title off)
(connect D3:1 D0:1
(points 4 329 280 350 280 350 300 393 300)
(connect D4:1 D0:2
(points 4 329 340 350 340 350 320 393 320)
(connect D5:1 D0:3
(points 4 242 500 360 500 360 340 393 340)
(connect D6:1 D0:4
(points 6 432 520 450 520 450 380 380 380 380 360 393 360)
(connect D2:1 D1:1
(points 4 467 140 490 140 490 120 751 120)
(connect D7:1 D1:2
(points 4 716 280 730 280 730 260 751 260)
(connect D13:1 D2:0
(points 3 295 -20 320 -20 320 32)
(connect D16:1 D5:0
(points 7 97 170 120 170 120 200 90 200 90 350 180 350 180 368)
(connect D16:1 D6:0
(points 9 97 170 120 170 120 200 90 200 90 630 260 630 260 380
370 380 370 388)
(connect D0:1 D7:1
(points 4 606 330 630 330 630 270 683 270)
(connect D12:1 D7:2
(points 6 996 480 1020 480 1020 380 660 380 660 290 683 290)
(points 11 97 170 120 170 120 200 90 200 90 630 270 630 270 650
460 650 460
500 570 500 570 518)
(points 13 97 170 120 170 120 200 90 200 90 630 270 630 270 650
460 650 460
390 670 390 670 380 760 380 760 538)
(connect D8:1 D12:1
(points 4 719 430 730 430 730 450 783 450)
(connect D9:1 D12:2
(points 4 719 490 740 490 740 470 783 470)
(points 6 632 650 680 650 680 520 750 520 750 490 783 490)
(points 6 822 670 840 670 840 530 770 530 770 510 783 510)
(points 4 210 -68 210 -60 250 -60 250 -48)
(points 6 210 -68 210 -60 190 -60 190 -50 70 -50 70 32)
(points 5 115 60 140 60 140 110 70 110 70 157)
11 1 13 14 15 16 10)
(titleBg "Gray")
(titleFg "Black")
(numberFormats
(realSigDigits 4)
(realRadixSpec 4)
