Hello from Gregg C Levine
I agree. I've got three of those here. And each time I click them,
that's what I get.
Rufus can you resend everything without that peculiar encryption
attached? I find it most annoying. Especially since at the bottom of
each message I see inside webmail a comment that the actual one wasn't
allowed. I strongly disagree with the IT weeny that insists on using
them. He, or it, hasn't the foggiest of notion of why they should be
used.
Gregg C Levine hansolofalcon@worldnet.att.net
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke." Obi-Wan Kenobi
> -----Original Message-----
> From: Shawn Fessenden [mailto:shawn@testech-ltd.com]
> Sent: Thursday, December 23, 2004 5:17 PM
> To: VRF
> Subject: [vrf] RE: is VRF down?
> > Hello Scott,
> I think Nic & Scott will be away until Jan. 4.
> > I was wandering if VRF is down
> Not really - not totally, but I do see a problem with agilent.com
DNS on and off.
> Don't know what it is, but it only seems to affect mail - the web is
fine.
> > Outlook cant even display the message and clicking the
> > item prompts me with Outlook warning saying your digital
> > ID name cannot be found by the underlying security system.
> Na, that's just Rufus sending encrypted or verifiable mail
> Oh look! There's another one now!
> -SHAWN-
that's what I get.
used.
> To: VRF
> > Hello Scott,
DNS on and off.
fine.
> -SHAWN-
Sent: Monday, December 27, 2004 9:13 AM
To: VRF
Subject: [vrf] RE: ADO Data Control 6.0 status
The compatibility status remark does not make a lot of sense. VEE is very
friendly as a Windows APP, and as far as I know, all window's app can
communicate with any loaded MS software. From what I can tell, the ADO are
fair game but you'll need a database somewhere, either a database server or
something like MS Access. But I think any compatible freeware will also
work.
Anyway, I use the DAO Engine and Access and have had no problems. There's
some confusion as to what to use in Windows, seems Windows has taken a turn
as to how it deploys its database control objects. So when you pick an
object, I've found it best to stay with one object since each treats the
data objects differently.
Now, for the last bit of confusion, I use DAO since there is an AGILENT
example. Also, when I open a database and then a recordset, I load my
variables directly from the database, or write them directly to the data
base, then close all. This will not be a good idea if you spend a lot of
time with the database open. You will want to use the dataset objects,
which I think are part of the .NET family.
So, this is my way of not being very helpful.
Rufus
Rufus Warren
Test Engineer
AMTI
2929 Sabre St.
Virginia Beach VA, 23452
Work: 757-431-8597
Making a Difference -- One Product, One Service at a Time
________________________________
From: VEE Pro(JC Park) [mailto:jcpark@kornets.co.kr]
Sent: Sunday, December 26, 2004 7:46 PM
To: VRF
Subject: [vrf] ADO Data Control 6.0 status
Hi VRF,
Anyone knows VEE's compatibility status of ADO Data Control 6.0?
VEE Help says:
VEE does not support all ActiveX Controls. If a control is incompatible with
VEE, an error will probably occur when you add the control to your program
or while you are using it.
At the time VEE 7.0 was released, the following ActiveX Controls were known
to not work well with VEE and should be avoided:
image/cbullet.gif Microsoft Forms Object Library
image/cbullet.gif Microsoft ADO Data Control 6.0
JC Park
