to: Johannes Mulder / VRf
date: Wednesday, 10 April 1996 1049 MDT
> A question just came up here:
> People in my department needs to read some digital statuslines,
> analogue voltages, drive some digital controls and maybe an analogue
> control.
> They also need to measure timerelations in, let's say, 0.1 sec
> accuracy. All via their PC of course.
> Currently they are looking to hard- and software from NI.
> I suggested them to look to HP-VEE (what else!).
> My question is: will it be difficult to exercise the AT-MIO boards
> from NI with HP-VEE? Is there any experience concerning this?
> Or is there a good alternative for this hardware?
You can write a DLL or use the PEEKPOKE DLL from VEE to control the card.
However, if you are using an NI card, an NI applications package will be
much more fine-tuned to work with them.
If you can use Data Translation cards, then the DT package for VEE will be
highly suitable for your use.
> Any good suggestion is welcome.
> With kind regards,
> Johannes Mulder
> Philips Electron Optics
> Building AAE-room 21
> P.O.B. 218
> 5600 MD ACHT, the Netherlands
> tel +31 40 2766947
> fax +31 40 2766820
[<>] regards -- gvg
> control.
> With kind regards,
> Johannes Mulder
> P.O.B. 218
> tel +31 40 2766947
> fax +31 40 2766820
[<>] regards -- gvg
