This mail is just for your information.
When I try to "Declare Variable" with a name "AB" or "A\B"
I get a "VEE Error, Invalid variable/terminal name, Error Code: 622".
FUKUI Yutaka
"Alexander Poulikakos (KI/EAB)" wrote:
> This will do it.
> /Alex
> -----Original Message-----
> From: Soeren.Hedemand@nokia.com [mailto:Soeren.Hedemand@nokia.com]
> Sent: den 15 december 2004 10:19
> To: VRF
> Subject: [vrf] Problem with Deletevariable
> Hi all.
> I'm trying to write some cleanup function for a large program, but I've come across a problem:
> If I make a Delete Variable box with the variable name for an input and an error output, and the variable name I input happens to contain a "", Vee stops with a runtime error that is not caught by the error pin. See attached. What is wrong?
> /Sren
> <<Deletevar.vee>>
> Deletevar.veeName: Deletevar.vee
> Type: VEE Program (application/x-unknown-content-type-VEE.Program)
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
* @LiFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
* x $B (BÊŠ $B%g (B $B%_ (B@H
* Ì‚Ã‚è „i{E $B; (BZpJ@ $B; (BZpPj <-- 2004/10/01
Eς܂
* vݔJHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
* $B f (Bã ¬cS-P-P@XÖ”Ô F211-8588
* TEL @O 044-754-3661,@ 711-3-1966,7 <-- 2004/09/27O
Ü‚
* FAX @O 044-754-3509,@ 711-3-5359
FUKUI Yutaka
> This will do it.
> /Alex
> To: VRF
> Hi all.
> /Sren
> <<Deletevar.vee>>
* @LiFUKUI Yutaka)
Eς܂
Ü‚
<b><span style='font-weight:bold'>From:</span></b> jim.hetrick[mailto:jim.hetrick@delphi.com]
<b><span style='font-weight:bold'>Sent:</span></b> 15 December 2004 10:08
<b><span style='font-weight:bold'>To:</span></b> VRF
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] RE: VeeTV episode 2</span></font></p><p class=MsoNormal style='margin-left:36.0pt'><font size=3face="Times New Roman"><span style='font-size:12.0pt'><![if !supportEmptyParas]> <![endif]><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:36.0pt'><font size=2 color=navyface=Arial><span lang=EN-US style='font-size:10.0pt;font-family:Arial;color:navy;mso-ansi-language:EN-US'>I tried to download each one and got thesame error message each time.</span></font><font color=black><span lang=EN-USstyle='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:36.0pt'><font size=2 color=navyface=Arial><span lang=EN-US style='font-size:10.0pt;font-family:Arial;color:navy;mso-ansi-language:EN-US'> </span></font><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoAutoSig style='margin-left:36.0pt'><font size=3 color=navyface="Times New Roman"><span lang=EN-US style='font-size:12.0pt;color:navy;mso-ansi-language:EN-US'>Thanks,</span></font><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoAutoSig style='margin-left:36.0pt'><font size=3 color=navyface="Times New Roman"><span lang=EN-US style='font-size:12.0pt;color:navy;mso-ansi-language:EN-US'>James Hetrick</span></font><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoAutoSig style='margin-left:36.0pt'><font size=3 color=navyface="Times New Roman"><span lang=EN-US style='font-size:12.0pt;color:navy;mso-ansi-language:EN-US'>EMC Engineering Technician/Software Developer</span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoAutoSig style='margin-left:36.0pt'><font size=3 color=navyface="Times New Roman"><span lang=EN-US style='font-size:12.0pt;color:navy;mso-ansi-language:EN-US'>CSE Test Center</span></font><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoAutoSig style='margin-left:36.0pt'><font size=3 color=navyface="Times New Roman"><span lang=EN-US style='font-size:12.0pt;color:navy;mso-ansi-language:EN-US'>(330) 306-1166</span></font><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:36.0pt'><font size=2 color=navyface=Arial><span lang=EN-US style='font-size:10.0pt;font-family:Arial;color:navy;mso-ansi-language:EN-US'> </span></font><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:72.0pt'><font size=2 color=blackface=Tahoma><span lang=EN-US style='font-size:10.0pt;font-family:Tahoma;color:black;mso-ansi-language:EN-US'>-----Original Message-----
<b><span style='font-weight:bold'>From:</span></b> Chris Hall[mailto:chris.hall@test-engine.co.uk]
<b><span style='font-weight:bold'>Sent:</span></b> Wednesday, December 15, 20045:05 AM
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] RE: VeeTV episode 2</span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:72.0pt'><font size=3 color=blackface="Times New Roman"><span lang=EN-US style='font-size:12.0pt;color:black;mso-ansi-language:EN-US'> </span></font><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:72.0pt'><span class=emailstyle17><fontsize=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial'>WorksOK for me.</span></font></span><font color=black><span lang=EN-USstyle='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:72.0pt'><span class=emailstyle17><fontsize=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial'>Iused Windows Media 390 MB. Maybe it depends which file you access.</span></font></span><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:72.0pt'><span class=emailstyle17><fontsize=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial'> </span></font></span><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:72.0pt'><span class=emailstyle17><fontsize=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial'>Regards</span></font></span><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:72.0pt'><span class=emailstyle17><fontsize=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial'>Chris</span></font></span><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:72.0pt'><span class=emailstyle17><fontsize=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial'> </span></font></span><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=2 color=blackface=Tahoma><span style='font-size:10.0pt;font-family:Tahoma;color:black'>-----OriginalMessage-----
<b><span style='font-weight:bold'>From:</span></b> barrie birmingham[mailto:b.birmingham@newi.ac.uk]
<b><span style='font-weight:bold'>Sent:</span></b> 15 December 2004 09:20
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] VeeTV episode 2</span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'> </span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=4 color=blackface="Times New Roman"><span style='font-size:14.0pt;color:black'>trying toaccess any of the downloads results in this message </span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p style='margin-left:108.0pt'><b><font size=5 color=blackface="Times New Roman"><span style='font-size:18.0pt;color:black;font-weight:bold'>-You are not authorised to view this page...... HTTP 403.6 - Forbidden:IP address rejected
Internet Information Services</span></font></b><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'> </span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=4 color=blackface="Times New Roman"><span style='font-size:14.0pt;color:black'>Anyone elsehaving problems?</span></font><font color=black><span lang=EN-USstyle='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'> </span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'> </span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=4 color=blackface="Times New Roman"><span style='font-size:14.0pt;color:black'>>Hivrf-ers,</span></font><font color=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=4 color=blackface="Times New Roman"><span style='font-size:14.0pt;color:black'>></span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=4 color=blackface="Times New Roman"><span style='font-size:14.0pt;color:black'>>Well, themuch-anticipated Episode 2 of Agilent VEE TV was >released to the</span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=4 color=blackface="Times New Roman"><span style='font-size:14.0pt;color:black'>>Agilentweb yesterday evening! As usual, the vrf is the first place it's</span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=4 color=blackface="Times New Roman"><span style='font-size:14.0pt;color:black'>>being announcedexcept for on the Agilent VEE TV web page itself.</span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'> </span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'> </span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'> </span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'> </span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'>-- BarrieBirmingham</span></font><font color=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:108.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'>b.birmingham@newi.ac.uk</span></font><fontcolor=black><span lang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:72.0pt'><font size=3 color=blackface="Times New Roman"><span style='font-size:12.0pt;color:black'>---
You are currently subscribed to vrf as: jim.hetrick@delphi.com
To subscribe send a blank email to"join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com". </span></font><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p><p class=MsoNormal style='margin-left:36.0pt'><font size=3 color=blackface="Times New Roman"><span lang=EN-US style='font-size:12.0pt;color:black;mso-ansi-language:EN-US'>---
You are currently subscribed to vrf as: chris.hall@test-engine.co.uk
If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com". </span></font><font color=black><spanlang=EN-US style='color:black;mso-color-alt:windowtext;mso-ansi-language:EN-US'><o:p></o:p></span></font></p></div>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></html><table><tr><td bgcolor=#ffffff><font color=#000000>****************************************************************************************
Note: The information contained in this message may be privileged and confidential and thus protected from disclosure. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by replying to the message and deleting it from your computer. Thank you.
</font></td></tr></table>
