> from: Greg Goebel / HP-MXD
> gvg@lvld.hp.com / 970-679-2305 / FAX 970-679-5971
> to: Alasdair Wilkie
> date: Tuesday, 21 May 1996 1407 MDT
> > Naive question,
> > We are using VEE3.12 on a PC running Win95 and find that when we switch
> > from the detail to the panel view, we need to move the window, then move the
> > window again when we switch back to the detail view, any way round this.
> I am not sure exactly what you are describing here ... but you may run into
Sorry to be a bit vague I shall describe the problem better
1. V.ini is set to open maximised.
2. Open VEE and file everything OK VEE maximised.
3. Switch to panel view, window now offset to the right and about half way
down the screen
4. Move window and maximise
5. Switch back to detailed view, window has again moved, maximise.
6. Switch to panel, window moved again.
This continues etc etc
> problems with VEE 3.12 on Win95. We recommend that you upgrade to VEE
3.2
> (E2120C Option AGE, $595 US) for Win95 support.
Unfortunately we have a combination of Win95 & Win3.11 users so the upgrade is
not feasible.
> > Many thanks
> > Alasdair Wilkie
> If you have other questions, let us know.
> [<>] regards -- gvg
We are using a screen setup with 1152 * 864 in true colour on a 17" monitor.
Although the problem occurs at other resolutions
Many Thanks
Alasdair
> to: Alasdair Wilkie
> > Naive question,
down the screen
3.2
not feasible.
> > Many thanks
> > Alasdair Wilkie
> [<>] regards -- gvg
Many Thanks
Alasdair
to: Alasdair Wilkie
> Naive question,
problems with VEE 3.12 on Win95. We recommend that you upgrade to VEE 3.2
> Many thanks
> Alasdair Wilkie
[<>] regards -- gvg
