VRf - IF v Cut/Paste
Question asked by VRFuser on Oct 16, 1996
> Hi,
> Thanks for the quick response on the BEEP issue, Greg.
> While I'm in the mood of griping, how about some sort
> of cut, copy, & paste function within an IF THEN ELSE
> box.  I've got a box with over 20 ELSE IF's and heaven
> help me if I have to insert another one near the top.
> Is there a way I don't know about to inset an ELSE IF
> anywhere EXCEPT the bottom, or a way to avoid re-typing
> each ELSE IF by hand to shuffle them all down one line?
Sure- quite easy. Just insert the ELSE IF where it pops in
(at the bottom) then pop over to your favorite text editor.
You can juggle the order all you want in a few seconds, since
they are all bunched together in one area.
Around here we use "vi" to solve all kinds of things like this.
Once you get used to the syntax it becomes very productive.
Do be careful though- you can create corrupt files if you are not careful.
Stan Bischof
stanb@sr.hp.com
