VRF: stability measurements
In our factory they do many stability measurements.
it's time to modernize.
the equipment we sell contains a PC.
THE path seems to me: use this PC and (something like) VEE.
My target: with not much effort (including as few as possible do
programming myself) doing this.
Question 1: does anybody have suggestions on which equipment to use.
We used the fluke 335 differential voltmeter with recorder. We need
at least 0.5ppm resolution, about 1kHz sampling should be
sufficient. I would prefer not to bother around in this PC, so either
serial or parallel communication. I'm focussing on the HP34420 and
the Keithley2002.
Question 2: is there already an application which can do the job?
I'm thinking of:
1-showing the result on screen
(maybe drift, noise and spikes separated)
2-some kind of warning on treshold-violations
3-logging to disk together with some documentation
4-retreiving files for reviewing or comparison
The PC runs WIN3.11, we're moving to NT, MSoffice (EXCEL) available.
Thanks for thinking
With kind regards,
Johannes Mulder
Philips Electron Optics tel +31 40 2766947
Building AAE-room 21 fax +31 40 2766820
P.O.B. 218
5600 MD ACHT, the Netherlands
the Keithley2002.
I'm thinking of:
Thanks for thinking
With kind regards,
Johannes Mulder
P.O.B. 218
