to: VRf
Hello
I have some major GPIB problems. I have 133 MHz pentium computer with
Win95 and HP 82341C HP-IB interface card. Problem is, that my
instruments doesn't understand commands that I try to send to them
with VEE.
For example, when I use instrument finder to send *IDN? inquiry to my
instrument that should respond to that inquiry, I can't get any
response and my instrument displays error message that indicates that
unknown header was sent. Results are always the same, no matter what I
try to send.
I found out with logic analyzer that only first byte of the inquiry was
sent and line feed after that. So *IDN? will shorten to *. What can
cause that? Is there any chances of configuration problem? I have had
response from my instrument with the following program, so the
instrument should be ok.
|Interface Op's : hpib7@7|
| EXECUTE CLEAR |
| SEND UNT |
| SEND UNL |
| SEND LISTEN9 |
| SEND MTA |
| SEND DATA "*" |
| SEND DATA "I" |
| SEND DATA "D" |
| SEND DATA "N" |
| SEND DATA "?" |
| SEND DATA "
|Keithley 2000 (@709) |
| READ TEXT x STR |
| EXECUTE LOCAL |
Does this sound familiar? If it does, please let me know how you worked
it out.
Date: Wed, 22 Jan 97 09:15:35 -0800
Subject: Re: VRF: Form Feed inside print
To: hpvxd_xc@hpislsup.lvld.hp.com, Stan Bischof <stanb@hpnmrsb2.sr.hp.com>
--- On Tue, 21 Jan 1997 16:01:33 -0800 (PST) Stan Bischof <stanb@hpnmrsb2.sr.hp.com> wrote:
> Hi
> here's a seemingly simple task that wortks fine under HPUX but seems
> a royal pain under Win 95:
> Namely I want to print some data, issue a form feed and then print
> some more data.
> Under HPUX I simple use a "to Print" object and
> write text a
> write text inttochar(12)
> write text b
> and it works great (12 is ascii decimal code for form feed)
> On my WIN95 PC this doesn;t work and the reason is alluded to in
> the "help" system: namely that "control characters" on the PC cannot be
> embedded in a print job. Sounds like a limitation of the print drivers
> rather than VEE per se.
> The suggested alternative is to use a _to file_ pointed at the
> printer port (LPT1 or whatnot) which seems klunky at best.
> Is there perhaps a better way of doing this?
> thanks for any hints
> Stan Bischof
> stanb@sr.hp.com
---------------End of Original Message-----------------
Stan,
You can include an "execute close" in the "to print" object that will force a form feed.
The only disadvantage to this is it actually creates 2 print jobs so if you have a banner
page you will get one in the middle of your printout.
E-mail: toms@symca.com (Tom Sanders)
Date: 01/22/97
Time: 09:15:36
Hello
with VEE.
try to send.
| EXECUTE CLEAR |
| SEND UNT |
| SEND UNL |
| SEND LISTEN9 |
| SEND MTA |
| SEND DATA "*" |
| SEND DATA "I" |
| SEND DATA "D" |
| SEND DATA "N" |
| SEND DATA "?" |
| SEND DATA "
| READ TEXT x STR |
| EXECUTE LOCAL |
it out.
> Hi
> some more data.
> write text a
> write text b
> Stan Bischof
> stanb@sr.hp.com
Stan,
Date: 01/22/97
Time: 09:15:36
to: Sami Ahokas
date: Wednesday, 22 January 1997 0843 MST
> from: Sami Ahokas (Sami.Ahokas@picker.fi)
> Hello
> with VEE.
Yes, the first-byte last-byte problem with the 82341C card has finally
been resolved after a year and a half of effort. We haven't published
anything yet because we have some minor problems to resolve, but you can
get the software fix off our support server:
CUSTOMER SERVER:
ftp://fcext3.external.hp.com/dist/mxd/pc/index.html
-> PCTM Support -> Drivers, Binaries, & Etc.
Sorry for the inconvenience.
[<>] regards -- gvg
