The first thing to check is the ouput of /etc/dmesg (or /usr/sbin/dmesg
on 10.X) for 2 lines that say something like:
SICL: Internal s7XX RS-232: Initialized ...
I suspect you either won't see this, or it will say failed.
The "address" field in hwconfig.cf is *very* model dependent,
what model 7XX do you have?
PS: This support is given on a best effort basis. I highly encourage
you to get a Response Center support contract for VEE and SICL if
you want timely support. Email me if you want details.
>Hi
>When I configure the port of my HP m/c with addr 9 10 ( for COM1 and COM2)
>respectively, and try to execute the Direct I/O object, it gives an
>error "No serial interface at addr 9"...Can you suggest me what could be
>the problem. In the systems file /usr/pil/etc/hwconfig.cf I have defined
>the ports as follows -
>9 COM1 serial700 0x00000001 26 9600 0x00 0x03 0x00 0x00 0x00
>10 COM2 serial700 0x00000002 25 9600 0x00 0x03 0x00 0x00 0x00
>Has anyone used the serial ports for communication, and can you kindly
>tell me, how exactly it is being done.
>Thanking You.
>mir
>Mir Mahiuddin,
>Hughes Software Systems,
>Electronic City,
>Plot No- 31, Sector - 18,
>Gurgaon - 122 015
>Tel - +91-124-343703 ext 2274
>Email : mmahiuddin@hss.hns.com
> mahiuddin@pemail.net
Mark Ahrens
Hewlett Packard T&M AEO Email: mark_ahrens@hp.com
(800)-452-4844
"Ask me about Custom Test Solutions"
>Hi
>Thanking You.
>mir
>Mir Mahiuddin,
>Electronic City,
>Gurgaon - 122 015
Mark Ahrens
(800)-452-4844
