VRF : Compiling of pil20.id
Question asked by VRFuser on Mar 25, 1997
Per.Bunch@nmp.nokia.com wrote:
> Hi
> I have received this driver (attached) from an instrument supplier. I
> want compile it to HP Vee 3.2 but when I run hpidc.exe I get the message
> "Line     2: (This file must be converted with BinHex 4.0)"
This means that it was (most likely) sent to you from a Mac user,
and was (for sure) encoded using a format called "binhex". Hence
before you can use it you need to decode it. Either round up a decoder
or get the sender to send it as plain text.
Stan Bischof
stanb@sr.hp.com
