Help!! Need Driver for CIO DAS 1602/16 (ComputerBoards inc.)
Question asked by VRFuser on Oct 28, 1996
> From: Bjarne.E.Roscher@medtek.haukeland.no
> Date: Mon, 28 Oct 96 14:26:19 +0100
> Subject: Help!! Need Driver  for CIO DAS 1602/16 (ComputerBoards inc.)
> To: hpvxd_xc@hpislsup.lvld.hp.com
>  I'm looking for a Driver for our DAQ Card from Computer Boards Inc.
>  which is called "CIO DAS 1602/16".
>  I'm asking You because I can't connect to the ftp/server of hp.
>  I tried it at this adress:
>  hplvopen.lvld.hp.com    or 15.255.16.2
>  Is this adress right or has it changed?
>  Bjarne Roscher
>  Haukeland Sykehus
>  med tek avd
Hi Bjarne,
Some things are beyond our local control, and the customer access
anonymous ftp machine you referenced, hplvopen.lvld.hp.com, was abruptly
replaced by fcext3.external.hp.com .  The directory structure remains
the same.
I hope to get the "hplvopen.lvld.hp.com" _name_ to point to the new
fcext3 machine, but we'll see, and then only for 6 months anyway.
So start using the new fcext3 machine name:
  ftp://fcext3.external.hp.com/dist/mxd/index.html     (= MXD front door)
  ftp://fcext3.external.hp.com/dist/mxd/pc/index.html  (= PC T&M front door)
Those pages eventually lead to the VXIplug&play Instrument Driver pages:
  ftp://fcext3.external.hp.com/dist/mxd/vxipnp/index.html      (html version)
  ftp://fcext3.external.hp.com/dist/mxd/v ... pdrver.lis    (text version)
And here are the Classic Instrument Drivers for HP VEE and ITG II pages:
  ftp://fcext3.external.hp.com/dist/mxd/v ... index.html  (html version)
  ftp://fcext3.external.hp.com/dist/mxd/v ... driver.lis  (text version)
The nslookup command tells me the fcext3.external.hp.com IP address
192.6.23.2 , but it could change without notice.
But you asked for a VEE driver for the CIO DAS 1602/16 DAQ Card from
Computer Boards Inc.:  I scanned the Classic Instrument Drivers for HP
VEE and ITG II pages for "CIO", "DAS", "1602" and found no matches.
Sorry.
I think Steven Timian (stimian@ara.com) had a good suggestion to call
Computer Boards at 508-261-1123 and ask about their "Universal Library
for HP VEE".
Hope this helps!
Please contact us if you have questions.
Ted Cline
PC Test & Measurement Online Support    Customer Support:        970-679-3030
Measurement Systems Division (MXD)      FAX:                     970-679-5260
Hewlett-Packard, M/S CU-326             Email:               pctm@lvld.hp.com
815 14th Street SW                      Customer Bulletin Board: 970-679-5978
P.O. Box 301                            Customer FaxBack:        970-679-3031
Loveland, CO 80537 USA       ftp://fcext3.external.hp.com/dist/mxd/index.html
