Thank you, Alex.
Maybe, you can give me another hint:
I am creating a real-time application. In short, I need to sample
frequencies of 256 devices under test (DUTs) every 7 min +/- 15 sec
and also communicate with them via RS-232 port using IEEE-488 GPIB
controlled switching network. On top of that, there may be a
considerable data reduction and operator data entry activity going on
at the same time. The way I intend to implement that is by using
multiple threads (one for frequency sampling, one for RS-232
communications, one for data analysis, one for operator interface refreshing,
etc).
The question is: how do I make frequency sampling thread to be the first
priority in execution, so that I measure frequency in specified time intervals?
Also, is there any way to prevent RS-232 communication objects from locking up
the system until they recieve appropirate response or time-out?
Sergey Ermolin
______________________________ Reply Separator _________________________________
Subject: Re: Accessing globals
Author: Non-HP-studnev (studnev@techdiag.msk.ru) at HP-SantaClara,shargw1
Date: 1/31/97 12:28 AM
Hi, Sergey,
A hint: if you are working with file, organize the functions
( including close file ) in ONE user function. In this case no other
objects can be called between open and close file - no collisions are posiible!
Alex
etc).
Sergey Ermolin
Hi, Sergey,
Alex
Hello.
What happens if two concurrently running threads in one HP VEE 3.21
program simultaneously try to access the same global variable (global
record in my case)? the same file?
Thank you.
Sergey Ermolin
