Re: VRF: Indeterminate string from instrument?
> From: Stan Bischof <stanb@hpnmrsb2.sr.hp.com>
> Date: Thu, 31 Oct 1996 09:04:00 -0800 (PST)
> To: hpvxd_xc%hpislsup.lvld.hp.com@hplb.hpl.hp.com
> Subject: VRF: Indeterminate string from instrument?
> Very simple problem:
> I want to read in a character stream from an instrument but have
> no way of knowing up front how long the stream is (is an HPGL output
> in this case). Am using DIO, but unlike "from string" or
> "from file" there is no
> READ TEXT x STR ARRAY:* (read till end of array) option available.
I wanted to do the same with my PM3382 scope. It works perfect, as
follows:
Using DIO with READ TEXT x STR (default num chars) (scalar)
DIO configured with ReadTerminator = "
Hope this helps you
With kind regards,
Johannes Mulder
Philips Electron Optics tel +31 40 2766947
Building AAE-room 21 fax +31 40 2766820
P.O.B. 218
5600 MD ACHT, the Netherlands
Date: Fri, 01 Nov 96 08:44:11 EDT
To: hpvxd_xc@hpislsup.lvld.hp.com, Stan Bischof <stanb@hpnmrsb2.sr.hp.com>
Subject: Re: VRF: Indeterminate string from instrument?
Hi Stan
I had the same problem in trying to read a HPGL plot output from
a network analyser, The following works well for me with no error
trapping involved.
WRITE TEXT "OUTPLOT" EOL
READ BINARY x STR
OUTPLOT in this case is the command I use to get the HPGL data.
The second line is the format you could try.
Regards
Ian Dalton M/A-Com Eurotec
______________________________ Reply Separator _________________________________
Author: Stan Bischof <stanb@hpnmrsb2.sr.hp.com> at corp
Date: 31/10/96 12:14
I can think of two ugly workarounds
(1) read a character at a time until an error occurs. Extremely slow
with full handshaking with every character.
(2) ask for a humongous array size- larger than I'd ever expect and
let the DIO error out, trapping and ignoring the error. At the same time
have the IO Moniotr active and logging it's output to a file. Read
in the file and sort out the returned string from it. Maybe faster than
above but very clumsy.
I'm assuming that my mind just isn;t working this AM and there's a simple
way to do this!
Someone please set me straight
thanks
Stan Bischof
stanb@sr.hp.com
Stan Bischof Hewlett Packard Company 707-577-3994 stanb@sr.hp.com
follows:
Hope this helps you
With kind regards,
Johannes Mulder
P.O.B. 218
Hi Stan
trapping involved.
READ BINARY x STR
Regards
way to do this!
thanks
Stan Bischof
stanb@sr.hp.com
way to do this!
thanks
Stan Bischof
stanb@sr.hp.com
to: VRF-Stan Bischof
date: Thursday, 31 October 1996 1025 MST
Do you want to read a single string or an array of them? What is the input
data format in general?
If you don't have a specific termination character at the end of the string
you can trap on, this is about all you can do. Unfortunately, VEE doesn't
know how to terminate on EOI (presuming that you use that).
> way to do this!
> thanks
> Stan Bischof
> stanb@sr.hp.com
[<>] regards -- gvg
