TO: gvg-at-lvld/HP-Sonoma_shargw1////////HPMEXT1/gvg#a#hpislsup#f#lvld#f#hp#f#com@hpcc815
CC: BRABETZ_LES/HP-Sonoma_om1@hpcc815,
BISCHOF_STAN/HP-Sonoma_om2@hpcc815
Item Subject: IEEE_728
Thanks Greq,
I already use the binary technique in all my work, but this is a
program written by another user (HP SSV) which they are proposing to send all
about the world. To implement the fix seems to require a lot of effort to find
all the reads and change them. If this is a know bug, is a fix in the works?
And why does the UNIX version work ok. Even the PC version works if the number
of bytes sent is Jussst right. Would I be far off guessing it has to do with
the interpretation of the int32 to the size of the allocation, and if you're
just lucky, the number is big enough to hold it all, but small enough not to
"bomb" out?
Thanks again,
Joel Dunsmore
joeld@sr.hp.com
______________________________ Reply Separator _________________________________
Subject: IEEE_728
Author: gvg-at-lvld (gvg@hpislsup.lvld.hp.com) at HP-Sonoma,shargw1
Date: 2/4/97 3:25 PM
send q IEEE_728 ww joeld@sr.hp.com
gvg@lvld.hp.com / 970-679-2305 / FAX 970-679-5971
to: Joel Dunsmore
date: Tuesday, 04 February 1997 1723 MST
> joeld@sr.hp.com # Joel Dunsmore at Hewlett Packard Sonoma County
> I am having a problem with reading instrument data using BinBlock.
> Every thing works fine on my Unix machine, but on the PC I get an error
> stating that the int32 value is out of range for the array size (I think it
> is the array size that is being looked at). I have tried setting the
> direct I/O to 488, and 488.2. All combinations work on the unix machine,
> none work on the PC. I am running V3.21 Apr 23 1996 version. The funniest
> thing is I think I got it to work once, but now I'm not sure.
> Any Help?
> Joel Dunsmore
> 1-577-4042
Sir:
Known bug ... I bet the device returns IEEE 728 data (check with the Bus
I/O monitor and make sure you have set your DIO accordingly):
#A<16-bit_int><data>
The int gives the length of the data. You can synthesize the proper read
through the following Direct I/O transactions:
READ BINARY NULL BYTE ARRAY:2 // Read #A.
READ BINARY x INT16 // Get length.
READ BINARY Y BYTE ARRAY:X // Read pin to get data.
Note how the length is read into pin X and then used as an array length for
the array in the last transation. If you want to read REAL data, say, you'll
need to divide it by 8.
Please let me know how this works.
[<>] regards -- gvg
Subject: Re: Re[6]: Barcode Reader Driver?
To: stanb@hpnmrsb2.sr.hp.com (Stan Bischof)
Date: Mon, 24 Feb 97 15:17:17 MST
> Fair enough! I now know where to look.
> One last thing: Would you mind sending me the material you have concerning
> serial interface to barcode readers?
Urk ... I looked around and it appears I tanked them a year or two ago.
Sorry about that.
> email or fax to 577-3332 would be great
> thanks again
> Stan
> Stan Bischof Hewlett Packard Company 707-577-3994 stanb@sr.hp.com
Subject: Re: P&P Drivers
Date: Mon, 24 Feb 97 15:26:39 MST
> Hi Greg
> I know that ITG driver devlopment has been halted and that P&P drivers
> are the way of the future. we've run into a situation here where users
> want drivers for instruments too new for ITG to have been done.
> They'd be willing to use P&P if they exist.
> My question to you is
> (1) Do any P&P drivers for VEE exist?
Yes.
> (2) If so from where can they obtained?
Try this:
http://hpislsup.lvld.hp.com/
-> PCTM Support -> Drivers, Binaries, & Etc. -> Plug & Play Drivers
> thanks
> Stan
Date: Tue, 25 Feb 97 8:54:55 MST
> Hi Greg
> Just noticed that there are no Unix P&P drivers that I could find.
Correct.
> DO you expect to ever offer P&P under HPUX? Given the rise of NT
> I'm 3/4 expecting the answer to be _no_.
They've waffled on this one but I am not holding my breath to see PNP on
HP-UX. However, this entire situation remains unstable.
> Stan
Thanks Greq,
"bomb" out?
Thanks again,
Joel Dunsmore
joeld@sr.hp.com
Subject: IEEE_728
to: Joel Dunsmore
> Any Help?
> Joel Dunsmore
> 1-577-4042
Sir:
[<>] regards -- gvg
Sorry about that.
> thanks again
> Stan
> Hi Greg
Yes.
Try this:
> thanks
> Stan
> Hi Greg
Correct.
> Stan
