>> I am writing test programs and would like to output the data
>> directly into EXCEL, or preferably ACCESS. Is there a listing of the
>> available DDE topics and commands for these programs? Any reasonable
>> suggestions on how to find or determine these commands?
>> Thanks in advance,
>> Dan Steigerwald
>> Hewlett Packard Company
>> Dan_Steigerwald@hp-sanjose-om1.om.hp.com
I reccommend simple TAB separated ASCII text files every time. Excel and
Access both import that format very easily.
If you use DDE with some particular application, you VEE program is
locked in to using that application. If, however, you write to a simple
ASCII file, you're free to use different applications to read/process
the generated data.
Hope this helps.
Regards
Gerry Murray
>> Thanks in advance,
>> Dan Steigerwald
the generated data.
Hope this helps.
Regards
Gerry Murray
Thanks in advance,
Dan Steigerwald
