I tried it again tonight, I installed Windows completely new to se where the
problem is!
I hav the Universal Library to drive my Computerboards DAQ Card, and it
seems to be incompatible with Win32s!
When i try to install it (UL-VEE) after Win32s then i get the Error: Regards
Win3.1 or Windows95!
Do you know a solution? I will also try to contact Computerboards.
Another Question: Is it possible to run VEE3.12 under Win95?
Thank You for your help so far.
Bjarne
At 09:59 05.11.96 MST, you answerd:
>> Hi all,
>> why does VEE 3.12 not work with Win32s?
>Seems to work fine here (we were running VEE 3.12 alongside HP BASIC for
>Windows, which installs Win32S, for a long time). Do you have any details?
>> I don't understand that. And my C-Version only runns with win32!
>> Can anybody give me an answer on this?
>> Thank You
>> Bjarne Roscher
problem is!
Bjarne
>> Hi all,
>> Thank You
>> Bjarne Roscher
