send q VRf-TCP_Handler_Query vrf ww KFJASINS@mail.delcoelect.com
to: Keith Jasinski
date: Wednesday, 06 November 1996 1645 MST
> I'm doing a manufacturing test program using Vee on an EPC-7 embedded system.
> I have the need to write traceability info out. Right now, I'm just mapping a
> network drive using Win95 and writing a file per DUT to the shared drive. In
> the future, we want to communicate with a host computer over TCPIP for our
> manufacturing information systems.
> We are using the ethernet module from Radisys that goes in the EPC-7. Is there
> a TCP handler out there that will work with Vee? How would the many of you out
> there handle this? I know someone out there has to have done some host
> communication of some sort.
The only tool for interfacing directly with the ARPA services in VEE is
To/From Socket. Does this meet your needs? If not, could you please clarify
the question?
> Thanks,
> Keith F. Jasinski, Jr.
> Milwaukee Design Center
> Department 1220-C
> Outside (414) 768-2427
> GM-Net 8- 521-2427
> FAX: -2820
Please stay in touch.
[<>] regards -- gvg
to: Keith Jasinski
the question?
> Thanks,
> Department 1220-C
> GM-Net 8- 521-2427
> FAX: -2820
[<>] regards -- gvg
